Schaublin 125-CNC retrofit.
- RotarySMP
- Thank you received: 595
29 Mar 2021 19:28 #204097
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Nice.
- RotarySMP
04 Apr 2021 10:02 #204724
by RotarySMP
I put it off long enough. Time for workshop tetris.
Enjoy.
Mark
Enjoy.
Mark
The following user(s) said Thank You: arvidb, tommylight, anfänger, timfaber
- arvidb
- Thank you received: 158
05 Apr 2021 01:59 #204842
by arvidb
Replied by arvidb on topic Schaublin 125-CNC retrofit.
Thanks! But can we *please* get back to the ballscrews soon?
I'm curious about what's wrong with them, making them so hard to turn. I hope it's just some gunked up fat and not any serious damage.
In all seriousness: it's interesting to see also how you handle moving the machines around - a crowbar, blocks of wood and a pallet jack seems to go a long way! Just after you got the lathe through the door you did some manouvering that made me think "he's done that before!". Just before you told us about towing 180 ton airplanes on ice .
- RotarySMP
05 Apr 2021 07:10 #204860
by RotarySMP
Yeah, I still need to pull the Z ball screw, and them strip, clean and relube them.
That move went better than I feared.
Mark
Mark
06 Apr 2021 00:52 - 06 Apr 2021 00:52 #205012
Replied by andypugh on topic Schaublin 125-CNC retrofit.
With a long crowbar you can "walk" things sideways.
Using CNC nomenclature: insert the bar at C = -90, raise machine by Z -N, move bar to C+90, Z = 0 and repeat.
This is a beast for that sort of thing if you are in the UK www.screwfix.com/p/roughneck-gorilla-wrecking-bar-48/29330
(I wonder if it their best-rated tool?)
Last edit: 06 Apr 2021 00:52 by andypugh.
- arvidb
06 Apr 2021 11:12 #205075
by arvidb
So use the crowbar heel as a pivot point?
- RotarySMP
06 Apr 2021 11:23 #205078
by RotarySMP
That blue crowbar I bought is similar. I brought the Boley and DoAll in with just an even smaller crow bar and rollers. The pallet jack sure makes it easier and faster.
Mark
Mark
- RotarySMP
11 Apr 2021 10:03 #205622
by RotarySMP
Here is this weeks video...
Enjoy
Enjoy
- J Green
- Thank you received: 24
11 Apr 2021 18:12 #205667
by J Green
Replied by J Green on topic Schaublin 125-CNC retrofit.
Mark
Enjoyed watching another U- Tube Schaublin video . Sure miss the Maho videos , any chance of more Maho action ?
Have you thought about having a live feed ? Maybe have a viewer poll for live feed .
I have used a aquarium small air pump to bubble the cleaning fluid during extended bearing or parts soaking . It provided a little agitation to the cleaning fluid over a lengthy soaking period .
Have read some of the concerns about using ultrasonic cleaning tanks for bearings . Always wondered if the bearings are in a preloaded state would the cautions still apply ? What do watch repair places use when cleaning a Patek Philippe Aquanaut ?
Machine moving
ww.casterhq.com/HRSP-GSPO-90G-p/hrsp-gspo-90g.htm 2200 thru 4400 Lbs( per set of 4 ) rated caster with adjustable leaveling height German Mfd. ? Blickle ? Add a missing " W " into the Web address .
Looks like something you could print a pattern an cast up with the foundry .
Bob
Machine moving
Bob
- RotarySMP
11 Apr 2021 18:21 - 11 Apr 2021 21:37 #205669
by RotarySMP
I haven't powered up the poor Maho for about 8 weeks now. Sooner or later I'll have to make up so new motor mounts though.
Good point about preloaded bearings in ultrasound. I have an ultrasound arriving next week, but only 10L, so the whole spindle wont fit.
Mark
Mark
Last edit: 11 Apr 2021 21:37 by RotarySMP.
The following user(s) said Thank You: DoWerna
Moderators: piasdom
Time to create page: 0.197 seconds
