Schaublin 125-CNC retrofit.
- RotarySMP
- Thank you received: 595
11 Mar 2021 15:19 #201822
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Thanks for your inputs guys.This really helps. Analog control it will be.
Mark
Mark
- tecno
- Thank you received: 127
11 Mar 2021 17:24 #201835
by tecno
Replied by tecno on topic Schaublin 125-CNC retrofit.
I got scammed by far east, ordered drivers with analog but got step/dir so I have to live with it, works.
Same brand...
So go with analog Mark.
Same brand...
- RotarySMP
11 Mar 2021 18:36 #201847
by RotarySMP
Thanks, which model number are your drivers?
Mark
Mark
- J Green
- Thank you received: 24
11 Mar 2021 18:44 #201849
by J Green
Replied by J Green on topic Schaublin 125-CNC retrofit.
andypugh
Could or would you elaborate about the 12Volt DC PC Motherboard you are using ? A 12 Volt DC board would save needing a PC power supply an it's mounting space.
Mark
Would re-encasing tho old MAHO computer power supply be of use ?
Mark
- RotarySMP
11 Mar 2021 18:58 #201851
by RotarySMP
The old Philips 432 PSU is optimised for the Phillips back plane adapter. I dont mind the little MeanWell HDR series din mount ones. They dont take much space. I might not even need 12V, if I put a Mini-ITX PSU up in the user modele with the PC.
Mark
Mark
- J Green
11 Mar 2021 20:35 #201856
by J Green
Again I wrote before re -looking at your (great) You-Tube Maho conversion overview . That Phillips 432 has the vertical power supply but later versions used a smaller horizontal type ,mounted under the card cage which slid into base of card cage frame.
I think MeanWell makes a good product in the sense of long term reliably .
It's just me ,but a 12 volt DC mother Bd. and a 12 volt DC LCD display would have many advantages over using a desk top type computer power supply configuration .
- Thank you received: 4654
12 Mar 2021 00:17 #201912
I am using a JNF9C-2800 but I don't think that they exist any more.
However all these are some variant of 12V power:
www.mini-itx.com/search?q=JNF9
(Some are 12V DC only, but one is 9-36V and another is 9-24V. 24V input is probably even more convenient than 12V input for our purposes). The quad ethernet daughter board on that same page might be interesting for Mesa card use.
You can use their board finder to find others 12V boards, and with PCI or parallel port too. www.mini-itx.com/products/boards
Replied by andypugh on topic Schaublin 125-CNC retrofit.
andypugh
The following user(s) said Thank You: J Green
- RotarySMP
12 Mar 2021 07:35 - 12 Mar 2021 07:37 #201933
by RotarySMP
I wont be so space limited up in the user module, so it doesn't really bother me what PSU's the PC needs. Would be nice to get one with the 12V input, but then i would probably stumble across a monitor with a 19V need
I considered an Odroid h2+, but at €150+ram+SSD, I am too cheap. I can pick up a Mini-ITX board with ram and SSD from the local classifieds for under €50 any day of the week.
Fun story, I saw a mini-ITX board, loaded, for €15 in my district.
Wrote: " Hi, please call me on +664 xxxxxxx so I can arrange to see it."
Received " Piss off, you dont honestly think i am going to call some dubious foreign number do you!"
Wrote " Sorry 0664 xxxxxxx - A1 Network"
This is the largest and most common cell provider here, and I would have thought that anyone here is familiar with 664 not being Thailand.
Never heard back.
Sometime the annonymity of the internet lets peoples true natue show, and not in a good way :-O
Mark
Never heard back.
Mark
Last edit: 12 Mar 2021 07:37 by RotarySMP.
- tecno
12 Mar 2021 08:28 #201937
by tecno
Lichuan B2
www.93x57r.se/tecno-cnc/CNC3000.html (still not installed :( )
/Bengt
Mark
Lichuan B2
/Bengt
- Hakan
- Thank you received: 454
12 Mar 2021 10:53 - 12 Mar 2021 10:58 #201943
by Hakan
Replied by Hakan on topic Schaublin 125-CNC retrofit.
Regarding the Lichuan A4 servo driver - I just installed two of those on my milling machine with 1kW servos.
Speed mode, analog +-10V input. Works just fine as far as I can tell. As is the case with the drives I have used,
speed/position/torque mode and input source are settable through drive registers.
Last edit: 12 Mar 2021 10:58 by Hakan.
Moderators: piasdom
Time to create page: 0.663 seconds
