- Thank you received: 595
Schaublin 125-CNC retrofit.
- RotarySMP
- Thank you received: 2177
github.com/mbuesch/pyprofibus/blob/master/doc/hardware.rst
Using the Linux serial port is a supported way to connect pyprofibus to a Profibus network. On some boards it may only supports low baud rates of up to about 19200 baud. However that depends on the actual serial transceiver hardware. On certain embedded boards with flexible serial hardware, high baudrates such as 1.5 MBaud may also be possible.To run pyprofibus on serial port configure pyprofibus as follows:[PHY]
type=serial
dev=/dev/ttyS0
baud=19200
What is the Profibus physical layer?
But really I don't know much about it. It just seems that there is a fair amount of used components around and a component for LinuxCNC seems useful.
[edit]
According to this www.profibus.com/index.php?eID=dumpFile&...07c7b3da955b47a8e10d one can use RS485 transmission technology.
More info here:
www.felser.ch/profibus-manual/elektrische_pegel.html
www.amazon.de/DSD-TECH-SH-U13-Krokodilkl...atibel/dp/B082KKG55T
(With the croc clips cut off)
I am using that to control a Modbus VFD.
- RotarySMP
In practice, I will put it on my "maybe i'll need this in the future" shelf, for permanent archiving.
