Schaublin 125-CNC retrofit.
5 years 2 months ago #217517 by andypugh
Replied by andypugh on topic Schaublin 125-CNC retrofit.
 with a partially complete Mach 3 / Stepper conversion,
Oh, the poor thing!
5 years 2 months ago #217554 by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Yeah really. Some idiot had hacked the end of the Z ball screw off, where it mounts the overload clutch and pulley. Luckily Harry has the connections to weld the stump back on and got it precision gound back concentric.
5 years 2 months ago - 5 years 2 months ago #217836 by RotarySMP
Another little step forward on this project.
Last edit: 5 years 2 months ago by RotarySMP.
The following user(s) said Thank You: arvidb, tommylight, anfänger, Aciera
5 years 2 months ago #218395 by RotarySMP
Another installment, of this trilogy in 56 parts...
5 years 1 month ago - 5 years 1 month ago #220587 by RotarySMP
The major components for the retrofit are slowing coming together. One of the goals is to shrink the space required by the Pneumatics significantly.
To advance that goal, I have bought this valve terminal...
I need six valves, and a separation between a single service with dry air and the rest lubricated. Also a mix of 2 way and four way valves (which Festo doesn't do, so it will be 5/3 and 3/2 valves). This module was on ebay germany and is the closest I could find with its divider module, mix of valve modules, endplates etc. This Festo CPV stuff is like advanced lego :)
It comes with the Fieldbus electrical interface module which seems to support a few protocols.
I saw that there is a PyProfibus HAL comp in the github.
github.com/mbuesch/pyprofibus
The git hub has a dead link to pyprofibus hardware documentation
I have searched this forum for more information about this comp, and other than a link to the 130 page Ethercat thread, dont find any worked examples. Is there a simple way to control a Fieldbus device through mesa cards, and LinuxCNC with the pyprofibux comp? I dont see the lathe needing realtime control of it's pneumatics, as it all just stuff you use during set up. (Tool change, tailstock and collet clamping, coolant valve, backgear)  Or should i just bite the bullet and buy a second terminal unit with a simple Multipol connector, and drive the individual valves with discrete wiring from Mesa outputs.
Mark
Last edit: 5 years 1 month ago by RotarySMP.
5 years 1 month ago #220589 by andypugh
Not that I can see. The driver seem to want to find a node in /dev/
github.com/mbuesch/pyprofibus/blob/maste...200s/pyprofibus.conf
And the Messa card UARTs etc are not accessed that way, generally.
It probably could be done, but it's probably not the easy way.
Time to create page: 2.080 seconds
