Schaublin 125-CNC retrofit.
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
26 Sep 2021 11:50 #221627 by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
As I have nearly all the major components now, my excuses for not getting into the retrofit are wearing thin.
The following user(s) said Thank You: arvidb, tommylight, anfänger
  • RotarySMP
  • Platinum Member
  • Platinum Member
03 Oct 2021 11:52 #222096 by RotarySMP
While waiting for Pneumatic components...
  • Ausschuss-Manufaktur
  • New Member
  • New Member
06 Oct 2021 02:58 #222329 by Ausschuss-Manufaktur
Replied by Ausschuss-Manufaktur on topic Schaublin 125-CNC retrofit.
Thank you for the videos, love your work.
I have to say, I’m a bit jealous about your manual tailstock. What a beauty!
Did you ever think about putting linear scales on the machine? Or do you think it is overkill when having Schaublin mechanics and ballscrews?
Sorry if you already said something about this topic and I missed it.
Keep up the great work!
The following user(s) said Thank You: RotarySMP, DoWerna
  • RotarySMP
  • Platinum Member
  • Platinum Member
06 Oct 2021 05:59 #222331 by RotarySMP
I have considered it. It would be easy to fit a linear scale to the Z axis, but would be difficult to do a decent installation on the cross slide without chewing up space. It might be possible to hang the X axis off the back. I might take another look at this once I get closer to finished. I doubt it will add much to accuracy.
Mark
  • New Member
  • New Member
06 Oct 2021 06:33 #222334 by Ausschuss-Manufaktur
Yes, x axis placement is probably the biggest problem. On my Colchester Lathe the linear scale is also on the back of the cross slide. Not too nice when you want an compact machine. And the enclosure is probably in the way too.
Really looking forward to see the capabilities of the machine.
Lorenz
  • RotarySMP
  • Platinum Member
  • Platinum Member
10 Oct 2021 11:13 #222733 by RotarySMP
The schaublin does have a pretty limited X travel, so you would nor need a very long scale, but I will start my conversion without. I am going to feed through the Servo encoder signals to LinuxCNC though.
  • RotarySMP
  • Platinum Member
  • Platinum Member
07 Nov 2021 11:00 #225555 by RotarySMP
Finished the cabinet chop at least. Had to spice this one up with extra aviation tales while watching the paint dry. Hope you dont mind :)
Regards,
Mark
The following user(s) said Thank You: arvidb, anfänger
  • RotarySMP
  • Platinum Member
  • Platinum Member
13 Nov 2021 09:43 #226291 by RotarySMP
I want to bench test my Festo CPV10--> Mesa 7i84-->7i85-->7i92.
The mini pc which I ordered has not arrived yet, so I figured I'd do a live install with the latest preempt image on my laptop for testing.
I have the 7i92 powered up and connected, but can't ping 192.168.1.121
I see there I need to switch network managers from WICD to network-manager.
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
Wish me luck :)
Mark
  • RotarySMP
  • Platinum Member
  • Platinum Member
13 Nov 2021 09:50 #226293 by RotarySMP
Did not take long for that to fail. Looks like you need to be SUDO to do apt-get install network-manager network-manager-gnome. Anyone knwo the SUDO credentials of the Live Install for 2.8.2? Is it even a good idea to try this in the live install?
Mark
  • Moderator
  • Moderator
13 Nov 2021 09:50 #226294 by tommylight
Replied by tommylight on topic Schaublin 125-CNC retrofit.
Get the new 2.8.2 ISO, it should have network manager.
Downloaded it last night, did not have time to check yet.
Moderators: piasdom
Time to create page: 0.185 seconds
