Schaublin 125-CNC retrofit.
- RotarySMP
- Thank you received: 595
13 Nov 2021 18:18 #226342
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Thanks Tommy. I got some help from my Linux guru, so now it is time to disconnect the mini pc and go and try it in the basement. Unfortunately it does not have a wifi adapter.
- RotarySMP
13 Nov 2021 18:41 - 13 Nov 2021 18:46 #226344
by RotarySMP
Now when I ping 192.168.1.121, I get one line with
ping 192.168.1.121 (192.168.1.121) 54 (86) bytes of data
and then continuous lines of
from 10.10.10.11 icmp_seq=[line number] destintion host unreachable.
Pinging 10.10.10.10 returns the same behavior.
I have no network admin experience. Any help appreciated.
Mark
Mark
Last edit: 13 Nov 2021 18:46 by RotarySMP.
- RotarySMP
13 Nov 2021 18:58 - 13 Nov 2021 19:18 #226347
by RotarySMP
Got it. Needed to jumper for 10.10.10.10. Now it works.
When you do show pins, is there are suffix to make the list break into columns, or dump to a file, as you cant read them all in the terminal?
From Peters post...
forum.linuxcnc.org/38-general-linuxcnc-q...-7i85s?start=0#68002
You probably want this firmware:
7i92_7i85sx2D.bit
which you fetch from mesa and install with mesaflash
sudo apt-get install mesaflash
mesaflash --device 7i92 --write 7i92_7i85sx2D.bit (write the 7I92 flash memory with 7I85S firmware)
mesaflash --device 7i92 --reload (load the FPGA with the new firmware)
mesaflash --device 7i92 --readhmid (read out the current pinout/modules)
(I think mesaflash will use the default 192.168.1.121 IP address if not specified,
if not or if you changed the 7I92s IP address, you need to add the address to the mesaflash command line)
What is the correct syntax for adding the ip address? I tried:
mesaflash --device 7i92 --write 7i92_7i85sx2D.bit 10.10.10.10
mesaflash --device 7i92 --write 7i92_7i85sx2D.bit ip=10.10.10.10
...looked up mesaflash --help
mesaflash --device 7i92 --write 7i92_7i85sx2D.bit --addr 10.10.10.10
mesaflash --device 7i92 --write 7i92_7i85sx2D.bit --addr <10.10.10.10>
but keep getting "no 7i92 board found?
Mark
From Peters post...
7i92_7i85sx2D.bit
Mark
Last edit: 13 Nov 2021 19:18 by RotarySMP.
- Henk
- Thank you received: 92
13 Nov 2021 19:52 #226354
by Henk
Replied by Henk on topic Schaublin 125-CNC retrofit.
mesaflash --device 7i92 --addr 10.10.10.10 --write 7i92_7i85sx2D.bit
- RotarySMP
13 Nov 2021 20:26 - 13 Nov 2021 20:28 #226361
by RotarySMP
It is returning "no 7i92 board found",
but if I do
halrun
loadrt hostmot2
loadrt hm2_eth board_ip=10.10.10.10
show pin
I get a fully functioning 7i92. Could this still be the outdated mesaflash issue? The installation is the latest 2.8.2 Buster ISO.
but if I do
halrun
loadrt hostmot2
show pin
Last edit: 13 Nov 2021 20:28 by RotarySMP.
- RotarySMP
13 Nov 2021 20:31 #226362
by RotarySMP
Forget it. I had an extra space between -- and addr!
- RotarySMP
14 Nov 2021 11:00 #226449
by RotarySMP
I wanted this video to be a victory of man over machine, but again, the machine won.
The following user(s) said Thank You: arvidb
- anfänger
- Thank you received: 270
14 Nov 2021 11:29 #226451
by anfänger
Replied by anfänger on topic Schaublin 125-CNC retrofit.
This always one of my gigots fears, forgetting a jumper or frying one of the cards while testing. I hope It's a simple fix.
- RotarySMP
14 Nov 2021 11:41 #226453
by RotarySMP
Peter has given me a suggestion of how to localise the fried component. Worst case I'll have to buy a replacement. Stupid of me.
Mark
Mark
- anfänger
14 Nov 2021 13:25 #226464
by anfänger
good luck there.
On my lathe I have fuses to protect the mesa cards if shorted.
And you reminded me to do the same on my running project.
Moderators: piasdom
Time to create page: 0.300 seconds
