- Thank you received: 595
Schaublin 125-CNC retrofit.
- RotarySMP
3 years 6 months ago #268689
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Hi Ralph,
Thanks for taking the time to give me your insights. That is a really helpful. I really like your control panel, It looks very practical.
I have a lot of comments through YT as well, and will need to work though it all in my head to see what gels together.
- spumco
- Thank you received: 905
3 years 6 months ago #268693
by spumco
Replied by spumco on topic Schaublin 125-CNC retrofit.
Make a cardboard mockup and pretend going through all the normal machining steps.
- Setup
- tool touchoffs
- measuring parts in situ
- programming
- editing programs
- Running a program
- Starting program
- Adjusting FRO/SRO while machining
- Single-blocking through the program
- Pausing/stopping
- Jogging away from part
The following user(s) said Thank You: RotarySMP, tommylight
- RotarySMP
3 years 6 months ago - 3 years 6 months ago #268698
by RotarySMP
I am coming to this conclusion as well, that I need to break out the CAD (cardboard a.. D..).
I need to order a second 7i73 for that front rail, sliding pendant as well, as it will be much more than I first envisaged.
Last edit: 3 years 6 months ago by RotarySMP.
- smc.collins
- Thank you received: 139
3 years 6 months ago #268703
by smc.collins
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
this is my temp configuration, x z rapid joystick, x z mog dials, connector for my foot switch for my chuck " i wrote a hal component for this check hal examples" .
everything else is pretty much dead. I'm not a fan of having turret jog controls, long borings etc will hit stuff. better to write a macro that calls g28 for a tool change and move the carriage somewhere safe
I'm still prototyping my controls layout, but it's going to be a variation of this with some dedicated buttons.
- spumco
3 years 6 months ago #268728
by spumco
Very, very good point.
- smc.collins
3 years 6 months ago - 3 years 6 months ago #268733
by smc.collins
I get super paranoid with some of my large drill bits, I have a 3 inch drill that is 14 inches long out front of the tool block, and that thing will smash shit. I am working on writing some macros for tool change related stuff. heres my attempt
see post below for edit
and some hal file stuff
net jog-tool-up halui.mdi-command-00 <= your_input_pin_for_tool_up
net jog-tool-down halui.mdi-command-01 <= your_input_pin_for_tool_down
setp halui.mdi-command-00.string "O<jog_tool_up_down> CALL"
setp halui.mdi-command-01.string "O<jog_tool_up_down> CALL"
and more info
[RS274NGC] ... SUBROUTINE_PATH = /path/to/your/subroutines/directory
I think this will require adding the macros to the INI file as well. I haven't made it that far yet. I started working on a macro to move y Z up and down during toolchanges, because the carousel on my SLV40 only goes left/right or along the X , the bmc20 has the carousel move up and down and the bmc30 is like the slv40, so I started with the carousel I had the most of.
I scratched this down on some notepad and had chat gpt clean it up, TEST CAREFULLY I HAVE NOT TESTED THIS CODE
and more info
Last edit: 3 years 6 months ago by smc.collins.
Moderators: piasdom
Time to create page: 0.259 seconds
