Schaublin 125-CNC retrofit.
3 years 10 months ago #259746 by tommylight
Replied by tommylight on topic Schaublin 125-CNC retrofit.
At 10m/div that looks really good.
Try faster.
3 years 10 months ago #259749 by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Thanks for the sanity check. It is difficult to work out when you stopped improving the tune, and are just chasing your tail.
I am pretty happy with X now. It sounds #right" all the way up to 3m/min. But then I put the micron clock on it, and looked at what happens with 10micron incremental steps. I can really see why industry when to closing the loop with linear scales.
The Z sounds more grumbly. Even when I soften up the drive, and dial back the P. I wonder if I have a mechanical issue in there somewhere?
The following user(s) said Thank You: smc.collins
3 years 10 months ago #259751 by RotarySMP
"have you calculated out the variables fpr the servo control and drive ??
max motor rpm = x velocity mm/sec"
Yes, I have both drives set for 150 RPM / V, so they will max out at 1500RPM.
X 1500 rpm -->1:2 --> 750 rpm screw --> 4mm pitch = 3m/min
Z 1500 rpm --> 1:3 --> 500 rpm screw--> 6mm pitch = 3m/min
My Ini is set for max rapid = 50mm/sec --> 3m/min
Those plots are with the LCNC PID. With the LCNC in open loop, the FError plot is useless, as it is just a divergent graph. In LCNC Open loop, all I could do was keep increasing the drive stiffness with auto tune values till is resonated, then back it off till stable.
3 years 10 months ago #259758 by smc.collins
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
Looks like you got it covered, are you now getting good motion and tracking all the way up and down your velocity commands ? if so, mission accomplished sir !
Can you post a video of the noise ?
3 years 10 months ago #259830 by RotarySMP
This is what it sounds like. With a night to sleep over it, it is not bad, it just sounds different.
3 years 10 months ago #259831 by tommylight
Sounds healthy on both, Z is heavier so more noise, more motor trying to cope with it, etc etc.
Moderators: piasdom
Time to create page: 1.023 seconds
