Schaublin 125-CNC retrofit.
3 years 6 months ago #268076 by PhilCNC
Replied by PhilCNC on topic Schaublin 125-CNC retrofit.
Thank you for all your content. What are your plans for a user interface panel? You need to have potentiometers for feed and speed overrides, and buttons for cycle start and feed hold. Here are some photos of what I’ve done, and what I have planned on my lathe.  It’s a copy of the Fadal control. In the garage. I prefer physical buttons in the garage machine shop. A mouse or touchscreen just feels cumbersome when wearing gloves.
3 years 6 months ago #268079 by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Thanks for the inspiration.
I use Gmoccapy, so I am going to duplicate the soft keys with a set of physical buttons around the touch screen like I did on the Maho. This will be up in the same place Schaublin put it. It will get a dedicated keyboard, which I already bought.
The soft keys of Gmoccapy already covers the start and feed hold buttons, but I might well duplicate them onto the pendant. Especially feed hold is very handy.
I will do a pendant down the front with two jog wheels dedicated to X and Y.
Definitely encoders for Speed and feed overrides, and jog speed. I will probably do physical buttons for the tool changer, and pneumatic tailstock clamping. Also the gearbox/back gear and variator might needs some love on the panel.
I need to collect my thoughts on this.
3 years 6 months ago #268080 by spumco
Replied by spumco on topic Schaublin 125-CNC retrofit.
OMG I cringed when I saw you starting to knurl with that floppy old thing.
If you must use that pinch holder, add a spring over the top arm to it to keep it centered(ish) and engage in X next to the shoulder then move Z+.
  • Engaging in X means it's more likely to self-align, and
  • You can easily check the Z- clearance during program prove-out
Yes, it's more money... but cut knurls are the ticket for CNC.  It's pretty easy to buy a single wheel and make a holder with a thrust bearing like this:
Single pressure knurls don't work great on flexible materials like in your vid, but they're nice as you can very easily adjust the knurl depth in G-code or tool offsets.
As usual, thanks for the vids.
3 years 6 months ago #268081 by RotarySMP
It was a cringy moment. I should have programmed that knurl as a multistart, coarse pitch, LH and RH thread.
3 years 6 months ago - 3 years 6 months ago #268129 by smc.collins
Replied by smc.collins on topic Schaublin 125-CNC retrofit.
I have added a joystick with rapid for X and Z and 2 jog wheels for fine adjust. I tried the whole pendant thing, not a fan for the lathe. Also my controls are just outside my chuck to the left. Once I get the new panel up and cleaned up versus my current hack job while waiting for material I will post a vid.
I see you have a tool changer, very interested to help you get that working. keep the videos coming too. good stuff
Last edit: 3 years 6 months ago by smc.collins.
3 years 6 months ago - 3 years 6 months ago #268264 by RotarySMP
By pendant, I mean a pair of dedicated handwheels mounted to a housing down on the front rail which the machine cover runs one, down on the stand,  like Schaublin did on the 125CCN. I only used one jog wheel with an X/Z switch on the mini lathe, and found it to be a PITA.
I saw you are working on a universal tool changer comp. Nice one. I will need to strip down and clean all the schmoo out of my tool changer, but think this is a prett simple one, with only a single control (Pneumatic valve for next tool), and two bits of feedback for the four positions. I haven't really got into it yet though.
Last edit: 3 years 6 months ago by RotarySMP.
Moderators: piasdom
Time to create page: 0.286 seconds
