- Thank you received: 5334
Here is a bitfile for a 5I24-25 with a 7I52S and a 7I52
You should be able to get the pinout with
sudo mesaflash --device 5i24 --dbname1 7i52S --dbname2 7i52 --readhmid
using this firmware and command i am getting this output:
P2-5,6:/Ena 0 IOPort None
P5-1,2,9,10 1 IOPort MuxedQCount 0 MuxQ-A (In)
P5-4,5,12,13 2 IOPort MuxedQCount 0 MuxQ-B (In)
P5-7,8,15,16 3 IOPort MuxedQCount 0 MuxQ-IDX (In)
P5-17,18,P4-1,2 4 IOPort MuxedQCount 1 MuxQ-A (In)
P5-20,21,P4-4,5 5 IOPort MuxedQCount 1 MuxQ-B (In)
P5-23,24,P4-7,8 6 IOPort MuxedQCount 1 MuxQ-IDX (In)
P3-9,10,17,18 7 IOPort MuxedQCount 2 MuxQ-A (In)
P3-12,13,20,21 8 IOPort MuxedQCount 2 MuxQ-B (In)
P3-15,16,23,24 9 IOPort MuxedQCount 2 MuxQ-IDX (In)
Internal-EncMux 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
P2-21,22 11 IOPort StepGen 5 Step/Table1 (Out)
P2-19,20 12 IOPort StepGen 5 Dir/Table2 (Out)
P2-13,14 13 IOPort StepGen 4 Step/Table1 (Out)
P2-11,12 14 IOPort StepGen 4 Dir/Table2 (Out)
P2-5,6 15 IOPort StepGen 3 Step/Table1 (Out)
P2-3,4 16 IOPort StepGen 3 Dir/Table2 (Out)
IO Connections for P3 -> 7I52
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
P2-5,6:/Ena 17 IOPort StepGen 2 Step/Table1 (Out)
P5-1,2,9,10 18 IOPort StepGen 2 Dir/Table2 (Out)
P5-4,5,12,13 19 IOPort StepGen 1 Step/Table1 (Out)
P5-7,8,15,16 20 IOPort StepGen 1 Dir/Table2 (Out)
P5-17,18,P4-1,2 21 IOPort StepGen 0 Step/Table1 (Out)
P5-20,21,P4-4,5 22 IOPort StepGen 0 Dir/Table2 (Out)
P5-23,24,P4-7,8 23 IOPort None
P3-9,10,17,18 24 IOPort SSerial 0 TXEn3 (Out)
P3-12,13,20,21 25 IOPort MuxedQCount 3 MuxQ-A (In)
P3-15,16,23,24 26 IOPort MuxedQCount 3 MuxQ-B (In)
Internal-EncMux 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
P2-21,22 28 IOPort MuxedQCount 4 MuxQ-A (In)
P2-19,20 29 IOPort MuxedQCount 4 MuxQ-B (In)
P2-13,14 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
P2-11,12 31 IOPort MuxedQCount 5 MuxQ-A (In)
P2-5,6 32 IOPort MuxedQCount 5 MuxQ-B (In)
P2-3,4 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
IO Connections for P2
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 34 IOPort MuxedQCountSel 6 MuxSel0 (Out)
14 35 IOPort SSerial 0 TXData5 (Out)
2 36 IOPort SSerial 0 RXData5 (In)
15 37 IOPort SSerial 0 TXData4 (Out)
3 38 IOPort SSerial 0 RXData4 (In)
16 39 IOPort SSerial 0 TXData3 (Out)
4 40 IOPort SSerial 0 RXData3 (In)
17 41 IOPort SSerial 0 TXData2 (Out)
5 42 IOPort SSerial 0 RXData2 (In)
6 43 IOPort SSerial 0 TXData1 (Out)
7 44 IOPort SSerial 0 RXData1 (In)
8 45 IOPort SSerial 0 TXData0 (Out)
9 46 IOPort SSerial 0 RXData0 (In)
10 47 IOPort SSerial 0 TXEn0 (Out)
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
it seems i am getting almost double encoder input on 7i52s and half of step/dir and on 7i52 same double encoder and only single sserial abd its also said DB25 pin while boards are 50pins is any firmware which gives 12 channel differential output (6 step/dir) + 6 channel encoder on 7i52s and 6 Channel encoder 6 channel Serial RS-422 on 7i52
