Greetings !!!!
@PWC
Could you please confirm drivers coz i am trying to drive X axis on TX0 (7i52s) its not working then i tried on TX5 (7i52s) its not working while try on TX2, TX3, TX4 its work perfectly i tried to swap both 5i24 and 7i52 with spared board its return same and i have also tried both drivers:
5i24_25_sssvst6_12_7i52s_7i52 = 5 step/dir, 1 PWM, 6 SSerial, 12 encoder
5i24_25_sssvst_6_12_6_7i52s_7i52d = 6 step/dir, 6SSerial, 12 encoder
both behave same.
Here is mine HAL and INI files
UPDATE !!!!!
i have swapped 7i52s and getting signals on stepgen channel 5 with 5i24_25_sssvst_6_12_6_7i52s_7i52d drivers but still not getting ant signals on ch 0 then i have checked voltage TX0A and /TX0A gives about 4.8V and when change direction it goes + to - vice versa but TX0B and /TX0B keep 0V no changes. So could you change driver 5i24_25_sssvst6_12_7i52s_7i52 where currently ch5 is pwm which i want to move to ch 1 and stepgen to ch 5 ??
