Mesa 5i24-25 stucked
3 years 9 months ago #262836 by PCW
Replied by PCW on topic Mesa 5i24-25 stucked
Sounds like maybe a wiring error or cable issue
The following user(s) said Thank You: yrsiddhapura
3 years 9 months ago #262852 by yrsiddhapura
Replied by yrsiddhapura on topic Mesa 5i24-25 stucked
@pcw yes it might be but like I said i checked continuity of connection from 7i73 pin 11(back side of 7i73 all cables connected) to switch and it shows continuity and 0.1 resistance which means there is no problem in connections and also checked if any pin is shorted but still it's there is no evidence of it so i swapped board with another 7i73 but still same problem
3 years 9 months ago #262857 by PCW
Still sounds like a wiring error. I verified that all column 0s work
(P1 pin 11 to 7,8,9,10 =R0C0,R1C0,R2C0,R3C0)
3 years 9 months ago #262878 by yrsiddhapura
will check again
3 years 9 months ago #262886 by PCW
To narrow things down, try with your cable unplugged and just short
P1 pin 11 to P1 pins 7,8,9,10 (one at a time)
Moderators: PCW, jmelson
Time to create page: 0.323 seconds
