Mesa 5i24-25 stucked
4 years 1 month ago #252506 by PCW
Replied by PCW on topic Mesa 5i24-25 stucked
That firmware is correct, It must be a Mesaflash error.
Does mesaflash show all 24 pins per connector if you don't use the --dbname option?
4 years 1 month ago #252509 by yrsiddhapura
Replied by yrsiddhapura on topic Mesa 5i24-25 stucked
Ok got it to utilize 7i52s and 7i52 board at fully functionality i have to wire it to connect all 3 connector at 5i24-25
4 years 1 month ago #252511 by yrsiddhapura
no its shows only 17 pin per connector:
lcnc@lcnc:~$ sudo mesaflash --device 5i24 --readhmid
[sudo] password for lcnc:
Configuration Name: HOSTMOT2
BoardName : MESA5I24
FPGA Size: 25 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 24
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 6 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P4
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort None
14 1 IOPort MuxedQCount 0 MuxQ-A (In)
2 2 IOPort MuxedQCount 0 MuxQ-B (In)
15 3 IOPort MuxedQCount 0 MuxQ-IDX (In)
3 4 IOPort MuxedQCount 1 MuxQ-A (In)
16 5 IOPort MuxedQCount 1 MuxQ-B (In)
4 6 IOPort MuxedQCount 1 MuxQ-IDX (In)
17 7 IOPort MuxedQCount 2 MuxQ-A (In)
5 8 IOPort MuxedQCount 2 MuxQ-B (In)
6 9 IOPort MuxedQCount 2 MuxQ-IDX (In)
7 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
8 11 IOPort StepGen 5 Step/Table1 (Out)
9 12 IOPort StepGen 5 Dir/Table2 (Out)
10 13 IOPort StepGen 4 Step/Table1 (Out)
11 14 IOPort StepGen 4 Dir/Table2 (Out)
12 15 IOPort StepGen 3 Step/Table1 (Out)
13 16 IOPort StepGen 3 Dir/Table2 (Out)
IO Connections for P3
1 17 IOPort StepGen 2 Step/Table1 (Out)
14 18 IOPort StepGen 2 Dir/Table2 (Out)
2 19 IOPort StepGen 1 Step/Table1 (Out)
15 20 IOPort StepGen 1 Dir/Table2 (Out)
3 21 IOPort StepGen 0 Step/Table1 (Out)
16 22 IOPort StepGen 0 Dir/Table2 (Out)
4 23 IOPort None
17 24 IOPort SSerial 0 TXEn3 (Out)
5 25 IOPort MuxedQCount 3 MuxQ-A (In)
6 26 IOPort MuxedQCount 3 MuxQ-B (In)
7 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 28 IOPort MuxedQCount 4 MuxQ-A (In)
9 29 IOPort MuxedQCount 4 MuxQ-B (In)
10 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 5 MuxQ-A (In)
12 32 IOPort MuxedQCount 5 MuxQ-B (In)
13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
IO Connections for P2
1 34 IOPort MuxedQCountSel 6 MuxSel0 (Out)
14 35 IOPort SSerial 0 TXData5 (Out)
2 36 IOPort SSerial 0 RXData5 (In)
15 37 IOPort SSerial 0 TXData4 (Out)
3 38 IOPort SSerial 0 RXData4 (In)
16 39 IOPort SSerial 0 TXData3 (Out)
4 40 IOPort SSerial 0 RXData3 (In)
17 41 IOPort SSerial 0 TXData2 (Out)
5 42 IOPort SSerial 0 RXData2 (In)
6 43 IOPort SSerial 0 TXData1 (Out)
7 44 IOPort SSerial 0 RXData1 (In)
8 45 IOPort SSerial 0 TXData0 (Out)
9 46 IOPort SSerial 0 RXData0 (In)
10 47 IOPort SSerial 0 TXEn0 (Out)
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
4 years 1 month ago #252513 by PCW
Strange, I'll see if I can duplicate that here.
I don't see that in the Mesaflash code, but will take a closer look.
The following user(s) said Thank You: yrsiddhapura
4 years 1 month ago #252515 by yrsiddhapura
ya sure but i have lil urgent to complete mine project.
4 years 1 month ago - 4 years 1 month ago #252544 by PCW
The Mesaflash --readhmid bug should be fixed (version 3.4.4)
Last edit: 4 years 1 month ago by PCW.
Moderators: PCW, jmelson
Time to create page: 0.350 seconds
