Mesa 5i24-25 stucked
3 years 10 months ago #259107 by PCW
Replied by PCW on topic Mesa 5i24-25 stucked
TX0B and TX3B need to be enabled specifically
(This is described in the 7I52S manual page 10 and controller pinout page 4)
If you are using the first connector, I/O bits 0 and 23 must be set low to enable TX0B and TX3B. You can do this by setting the "is_output" parameter of those pins.
On the second connector with a 7I52S, the enable pins would be I/O bits 24 and 47
3 years 10 months ago - 3 years 10 months ago #259116 by yrsiddhapura
Replied by yrsiddhapura on topic Mesa 5i24-25 stucked
@pwc
Ohw I think i am novice in Linuxcnc i have read it in manual but i thought it will be done in firmware (bitfile) and also have read about is_output in lcnc hm2 documentation
So i am using first connector (P4 of 5i24) for Stepgen and pwmgen and 6 encoder and second connector (P3 of 5i24) for 6 encoder and 6 sserial so yes to enable TX0B and TX3B i have to set io bit 0 and 23 by following syntax in hal file
hm2_5i24.0.gipo.0.is_ouput true
hm2_5i24.0.gipo.023.is_output true
Is that right
And do I need to set io bit 24 and 47 "is_output" to utilise all smart serial chanel ?
Last edit: 3 years 10 months ago by yrsiddhapura.
3 years 10 months ago #259118 by PCW
No, sserial firmware handles the enables
3 years 10 months ago #259119 by yrsiddhapura
@PWC
Does It will work ?
3 years 10 months ago #259121 by PCW
That's about right, but to determine actual hardware names run:
halcmd show all hm2 > hardware.txt
When linuxcnc is running
Now you have a list of all hardware pins and parameters (in hardware.txt)
you can use as a copy/paste source for editing your hal files
The following user(s) said Thank You: tommylight, yrsiddhapura
3 years 10 months ago - 3 years 10 months ago #259185 by yrsiddhapura
@PWC hope i am not messing your weekend.
Thank you for your all Help now i can move mine 3 axis X, Y, And Z
Thank you once again
Have a great weekend
Moderators: PCW, jmelson
Time to create page: 0.365 seconds
