Mesa 5i24-25 stucked
4 years 1 month ago #252624 by PCW
Replied by PCW on topic Mesa 5i24-25 stucked
Actually (as described in the 7I52S manual) its:
PULS- is TX0A
PULS+ is /TX0A
SIGN- is TX0B
SIGN+ is /TX0B
The following user(s) said Thank You: yrsiddhapura
4 years 1 month ago - 4 years 1 month ago #252625 by yrsiddhapura
Replied by yrsiddhapura on topic Mesa 5i24-25 stucked
Well thank you so much you just save me i have to change connection. Then it would be same in encoder connections too ?
Last edit: 4 years 1 month ago by yrsiddhapura.
4 years 1 month ago #252626 by PCW
The encoder polarity is basically "dont-care"
4 years 1 month ago - 4 years 1 month ago #252715 by yrsiddhapura
File Name: 5i24_25_ss...i52d.zip
File Size:147.04 KB
Here is a bitfile for a 5I24-25 with a 7I52S and a 7I52
You should be able to get the pinout with
sudo mesaflash --device 5i24 --dbname1 7i52S --dbname2 7i52 --readhmid
4 years 1 month ago #252716 by yrsiddhapura
Could i use 1 Chanel as pwm/dir with pwmgen
4 years 1 month ago #252807 by PCW
You would need different firmware
(more typically you would replace the last stepgen=stepgen5 with a PWMgen)
Moderators: PCW, jmelson
Time to create page: 0.348 seconds
