Hardinge HNC retrofit and where to start
- Thank you received: 4994
17 Jul 2012 23:04 #22110
Replied by andypugh on topic Re:Hardinge HNC retrofit and where to start
JR1050 wrote:
FWIW the Mesa 7i49 Resolver driver emulates the encoder index behaviour, so if the Resolver is a one-cycle-per-rev type (less than certain) then it would be usable for all the normal LinuxCNC spindle encoder things.
It's moderately easy to tell how many cycles-per-rev the resolver is. Power up the drives and put a multimeter in the AC range on one of the secondaries, then rotate the spindle. If you see the amplitude drop to zero more than once a rev then you would need to wire up a separate index or change it to an ABZ encoder.
I had imagined that the resolvers were more tightly integrated into the motors than appears to be the case. My servos have them inside the back of the case, and I would be looking at trying to source new connector inserts ($20 + the pins each) or the pin-removal tool ($100s) to change the wiring to suit encoders. I would also need to find some form of commutating encoder too, as mine are AC servos reliant on the absolute feedback that resolvers give.You would be WAY ahead of the game to buy some inexpensive encoders
- bobinater
18 Jul 2012 03:01 - 18 Jul 2012 03:02 #22112
by bobinater
Replied by bobinater on topic Re:Hardinge HNC retrofit and where to start
Last edit: 18 Jul 2012 03:02 by bobinater. Reason: same photo 3 times
- bobinater
18 Jul 2012 03:03 #22113
by bobinater
- bobinater
18 Jul 2012 03:04 #22114
by bobinater
- bobinater
18 Jul 2012 03:06 #22115
by bobinater
- bobinater
18 Jul 2012 03:08 #22116
by bobinater
- bobinater
18 Jul 2012 03:10 - 18 Jul 2012 03:13 #22117
by bobinater
Last edit: 18 Jul 2012 03:13 by bobinater.
- bobinater
18 Jul 2012 03:14 #22118
by bobinater
- bobinater
18 Jul 2012 03:16 #22119
by bobinater
- bobinater
18 Jul 2012 03:18 #22120
by bobinater
Time to create page: 0.340 seconds
