Planning - Bridgeport Interact 1 linuxCNC Retrofit
- csbrady
- Thank you received: 10
17 Jan 2016 15:16 #68588
by csbrady
Replied by csbrady on topic Planning - Bridgeport Interact 1 linuxCNC Retrofit
I have not tried inverse deadband yet, it's on my list. I am a little sceptical that it will help, but figured it's worth trying. I spent a lot of time searching for more information and found very little.
- cncnoob1979
- Thank you received: 75
18 Jan 2016 00:14 - 18 Jan 2016 00:27 #68636
by cncnoob1979
Replied by cncnoob1979 on topic Planning - Bridgeport Interact 1 linuxCNC Retrofit
I might have a go at reverse deadband, if so I'll post the results.
Here is an image of me placing my components into my pendant.
I mounted it this way because on the back, I'll have a hinge and spring loaded cables. That way I can access everything directly from the rear.
I'm not sure if I'll leave the plexi clear or not. I might paint it.
Last edit: 18 Jan 2016 00:27 by cncnoob1979.
- cncnoob1979
18 Jan 2016 21:17 #68719
by cncnoob1979
Ive ran into a snag I cant seem to figure out.
I'm trying to link my joystick commands to jog my axes. The outputs are 24v to the 7i77 via input TB8 pins 06-09. However I am getting no movement and looking through HAL configuration, the readings are false. Ive connected the pins via PncConf Wizard.
I haven't started tackling editing the hal file yet.
Ive posted my hal and ini files below.
Im reading up in the DOC's at the moment. Any help is much appreciated.
- Thank you received: 4654
18 Jan 2016 23:27 #68723
If you can't see any action on the hm2 input pins when you move the joystick then it is probably a wiring problem. How is the joystick connected? Perhaps the joystick connects pins to GND?
Replied by andypugh on topic Planning - Bridgeport Interact 1 linuxCNC Retrofit
- cncnoob1979
18 Jan 2016 23:43 - 19 Jan 2016 00:08 #68725
by cncnoob1979
Hey! Thanks Andy,
I looked at the input pins and they go to true when I use the joystick, and a true on jog-x-pos. So its getting the 24v, so Im not sure what I need to do?
Ive been trying to figure it out.
Edit:
I was looking at the wrong pins in my previous post [When I stated the pins were false]. I have found the correct pins as stated above and they are true, but still no movement. ~Just to clarify my issue.
Am I using the right pins for jogging? I cant seem to find simple literature to explain this to me. I see a ton of stuff for hand-wheels ect. Not simple connections.
Edit:
Last edit: 19 Jan 2016 00:08 by cncnoob1979.
19 Jan 2016 00:07 #68726
At a guess (and this is a guess) your halui.jog-speed is zero?
- cncnoob1979
19 Jan 2016 00:10 #68727
by cncnoob1979
My jog speed in the axis GUI is @ 15in per min.
Unless you mean elsewhere?
19 Jan 2016 00:14 #68728
I do mean elsewhere, I mean the halui.jog-speed pin itself.
That is, I think, independent of the slider, which is purely an Axis thing.
- cncnoob1979
19 Jan 2016 00:18 - 19 Jan 2016 00:30 #68729
by cncnoob1979
Awesome guess!
I looked at that pin in halmeter, it is currently zero [0], so where do I go from here?
Ill read up on that pin, I have no idea what to do with it!
This is in my hal file attached above:
I dont seem to have any mention of jog speed in my ini, so Im assuming I need to add it in the INI or in the HAL file.
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdiI dont seem to have any mention of jog speed in my ini, so Im assuming I need to add it in the INI or in the HAL file.
Last edit: 19 Jan 2016 00:30 by cncnoob1979.
19 Jan 2016 00:33 #68730
As a first step, try "setp halui.jog-speed 10" in the box at the bottom of the "show HAL config" window.
Then work out where you want the jog speed to be set.
Awesome guess!
I looked at that pin in halmeter, it is currently zero [0], so where do I go from here?.
Time to create page: 0.139 seconds
