biesse rover 316 retrofit
- Masiwood123
- Thank you received: 93
07 Jan 2022 22:47 #231071
by Masiwood123
Replied by Masiwood123 on topic biesse rover 316 retrofit
ok thanks
this ini and hal was later with that config. i will attach new ini and hal with last config after i update firmware and install network manager , and also follow and use instructions for network settings by tommylight
- Masiwood123
07 Jan 2022 23:55 #231078
by Masiwood123
- Thank you received: 5331
08 Jan 2022 00:05 - 08 Jan 2022 00:05 #231080
Replied by PCW on topic biesse rover 316 retrofit
Can you start LinuxCNC from the command line and copy-paste
any errors you get to the forum?
It's pretty hard to guess what "nothing better" means
Last edit: 08 Jan 2022 00:05 by PCW.
The following user(s) said Thank You: Masiwood123
- Masiwood123
08 Jan 2022 00:18 #231081
by Masiwood123
the hardware is 7i92 + 7i77, when i age the linux cnc configuration it throws out the error i pinned in the pictures and doesn't let me go, when i say nothing better i think nothing has changed in the sense that i have solved the access problem. and I did everything I know. I'm slowly thinking about selling cards and switching to mach3, I'm persistent and optimistic but this is too much
08 Jan 2022 00:26 #231082
What does
mesaflash --device 7i92 --addr 10.10.10.10 --readhmid
report?
The 7i92_7i77_7i74D firmware has a DPLL so the error only makes sense if the wrong firmware is installed
report?
- Masiwood123
08 Jan 2022 00:33 #231083
by Masiwood123
I can post a report tomorrow, I've already tried it as a beginner, it seems ok, but maybe it's not. I'm not in the workshop now. Thank you for your help
- Thank you received: 7488
08 Jan 2022 02:24 #231089
Replied by tommylight on topic biesse rover 316 retrofit
setp [HMOT](CARD0).stepgen.timer-number 1
That line seems fuzzy as there are no stepgens used, omit it by putting # in front of it.
Everything else seems OK from a quick glance.
08 Jan 2022 03:45 #231091
Ahh yes I missed that, need to comment that line out
Not sure if that is a pncconf bug or the wrong pncconf
firmware was chosen
firmware was chosen
- Clive S
- Thank you received: 486
08 Jan 2022 09:22 #231100
by Clive S
I said that in forum.linuxcnc.org/30-cnc-machines/44700...ofit?start=10#231068
The error shown is on line 26 in the hal file
setp [HMOT](CARD0).dpll.01.timer-us -50
I don't see the ref [HMOT](CARD0) in the ini file.
So try just try and comment it out with a # like #setp [HMOT](CARD0).stepgen.timer-number 1
To see if it loads
Replied by Clive S on topic biesse rover 316 retrofit
To see if it loads
The following user(s) said Thank You: tommylight, Masiwood123
08 Jan 2022 10:21 #231102
Yes you did mention it, sorry i did not.
And there is an entry in the ini file for 7i92.0
Time to create page: 0.238 seconds
