biesse rover 316 retrofit
- Masiwood123
- Thank you received: 93
11 Jan 2022 19:26 #231475
by Masiwood123
Replied by Masiwood123 on topic biesse rover 316 retrofit
if it should be pwm does it can be increased over 20k, in pnconfig it is disabled and fixed? we will see on other axis whan i connect all.
now i am trying to install and enter the pnconfig in mint 19.3, if it doesnt work will change pc as next step, even i think is ok Dell 980, i5 8gb ram nic on board.
- Thank you received: 5331
11 Jan 2022 19:31 #231476
Replied by PCW on topic biesse rover 316 retrofit
The PWM rate is set by the drives, there is nothing on the LinuxCNC side that can change it
The following user(s) said Thank You: Masiwood123
- Masiwood123
11 Jan 2022 22:15 #231493
by Masiwood123
- Masiwood123
12 Jan 2022 22:19 - 12 Jan 2022 22:22 #231620
by Masiwood123
Little progress today (big for me) I found that the freezing of linux is hopefully because of Pc, I replaced Pc today and after an hour nothing bad happened, following Tommy's instructions I got to the point when looking at halscope (but I'm not really clear that straight line..somehow everything goes fast and I can't see what's going on)..to be continued:)
Motor still sounds at high frequency both in operation and while standing. when I turn on all three axes the orchestra will play
Last edit: 12 Jan 2022 22:22 by Masiwood123.
- Thank you received: 7488
13 Jan 2022 07:17 #231636
Replied by tommylight on topic biesse rover 316 retrofit
Nice !
Did you setup the enable and e-stop control from LinuxCNC ?
- Masiwood123
13 Jan 2022 09:34 #231644
by Masiwood123
tha config is only p 0.25 an ff1 0,008 and it works without errors. estop is factory snake line i following trough all machine..it stops mechanical for now all relays, amps etc and it works, also every axis have one limit box with two contacts pins , one to disable driver and one for homing(have to figure how to wire it to 7i77 to have homing)Yes i wire ena switch on 7i77 and enable drivers works by linux cnc. Next step is to wire and tune x and z motors.. and next question should be how to make simple button like goto zero all axis (mach3)? for me it is very helpful gadget because i am woodworker and not doing with same panels.. often it is hard that machine offsets in factory origin and wooden pieces. my origin’s are usually in the center of wood piece and homing is not so necessary?
- Masiwood123
15 Jan 2022 22:02 #231942
by Masiwood123
new success today..x axis in use by Y axis settings and encoder replaced (factory was broken) in my opinion it works fine. Tomorrow I will hopefully run z axis. Spindle works by settings all great up to 18000rpm at 10v. What bothers me is that the axis screen has a spindle speed of 0-3000. My question is where can I change that?
- Masiwood123
15 Jan 2022 22:05 - 15 Jan 2022 22:06 #231943
by Masiwood123
also i dont have that ultrasound from X motor(all motors are the same) does encoder can make it , on X axis i put encoder omron 1000ppr(china) ..on y where is a sound is factory encoder 500ppr(needs 12v and power him from machine)?
Last edit: 15 Jan 2022 22:06 by Masiwood123.
- Masiwood123
16 Jan 2022 15:06 #232020
by Masiwood123
New problem appears.. when i try to assign input for home switch for y axis and anter som -10 to offset ( physical i didn’t mount switch to 7i77) after that both axix x and y jump about 10mm and break with following errors. i try to back all pncfg config as it was before but the same happens when i enabe drivers f2. any suggestions why it happens to even all fields have everything asme as before configuration worked fine?
- Masiwood123
16 Jan 2022 17:43 #232035
by Masiwood123
a new problem appeared when I tried to do homing i even didnt put 24v to input pin i wanted as home shwich, all axis jumps both before and after enable the driver(f2)... on the analog output 7i77 is not 0V, but as I measure it has 0.5-0.65v everywhere..do you know if it is a software or hardware problem with 7i77? Thank you
Time to create page: 0.242 seconds
