CMS MAXIMA 4 axis Machine retrofit
- Thank you received: 7506
22 Apr 2020 07:58 #165098
It is, it just needs up and down pulse trains on two inputs instead of the usual step/dir.
In the hal file you will have this
setp hm2_7i76e.0.stepgen.00.step_type 0
Change that to this, for the axis that that drive is wired to
setp hm2_7i76e.0.stepgen.00.step_type 1
Notice that the stpgen number might be 01 or 02 for that axis, like
setp hm2_7i76e.0.stepgen.01.step_type 1
or
setp hm2_7i76e.0.stepgen.02.step_type 1
Replied by tommylight on topic CMS MAXIMA 4 axis Machine retrofit
No.Do you mean that the driver is not capable for position control?
or
The following user(s) said Thank You: Yannis
- Yannis
- Thank you received: 4
22 Apr 2020 09:20 #165106
by Yannis
Replied by Yannis on topic CMS MAXIMA 4 axis Machine retrofit
So i go to the hal file for that
What about wiring .I have to connect all 4 cables?
22 Apr 2020 10:01 #165114
mesa to drive
step+ to PP
step- to PG
dir+ to NP
dir- to NG
You can get away with 3 but it is better with 4 as it is more immune to interference.So i go to the hal file for that
mesa to drive
step+ to PP
step- to PG
dir+ to NP
dir- to NG
- Yannis
23 Apr 2020 00:47 #165186
by Yannis
Previews i connect the the drive with uccnc Ethernet board uth 400 and it look like working (that mean that it was moving both directions in different speeds and run g code.)
How is that possible?
- bbsr_5a
- Thank you received: 106
23 Apr 2020 02:11 #165190
by bbsr_5a
Replied by bbsr_5a on topic CMS MAXIMA 4 axis Machine retrofit
the drive does have a positiv negative switch and also a Double edge mode 2Steps per Tick
- Yannis
23 Apr 2020 05:51 #165211
by Yannis
When i test the motor on the bench what values sud i place in the section of the pncconf for the motor encoder etc
( if its possible point me what i must read to calculate by my self since i have several different motor i like to test)
- Yannis
29 Aug 2020 01:32 #179916
by Yannis
Hello
i try to set up linuxcnc mesa 7i76e with DMM DYN 4 Driver
On the bench i can jog the motor with DMM software
when i wiring the motor with 7i76e i have no movement
Any suggestions?
Any suggestions?
- Yannis
01 Sep 2020 03:16 #180273
by Yannis
Hello
Any suggestions?
Any suggestions?
- Clive S
- Thank you received: 486
01 Sep 2020 04:13 #180282
by Clive S
Change these to 5000
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
Also have you connected the enable on the drive if so disconnect it to test
Replied by Clive S on topic CMS MAXIMA 4 axis Machine retrofit
Hello
Any suggestions?
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
- Yannis
01 Sep 2020 04:57 #180287
by Yannis
when i try with those settings i have oscillation
i can not distinguish any motion of the shaft ether clockwise or opposite
Time to create page: 0.164 seconds
