CMS MAXIMA 4 axis Machine retrofit
  • Moderator
  • Moderator
01 Sep 2020 05:10 #180292 by tommylight
Replied by tommylight on topic CMS MAXIMA 4 axis Machine retrofit
Pictures of everything, attach the config files, explain how and what is working and what not............
01 Sep 2020 05:17 #180296 by Clive S
Replied by Clive S on topic CMS MAXIMA 4 axis Machine retrofit
Tom he has already done that here. forum.linuxcnc.org/38-general-linuxcnc-q...ofit?start=60#179916
I have just noticed that he has STEP SCALE = 1 !!!
  • Moderator
  • Moderator
01 Sep 2020 05:40 #180301 by tommylight
Ooops, then this would be the second or the third time he is asking the same thing, or might not be the same user ?
The scaling of 1 wont do much, that would have to be calculated from the distance travelled per motor pulse.
01 Sep 2020 06:08 #180309 by Yannis
Replied by Yannis on topic CMS MAXIMA 4 axis Machine retrofit
I change the value from 1 to 50 and i have some movement with much oscillation
  • Moderator
  • Moderator
01 Sep 2020 06:12 #180311 by tommylight
Again, that has to be calculated and set exactly, not guessed.
And sorry, but we do need much more info to be able to help you.
So again back to my request, pictures, configs, drive pulleys/pinions/ballscrews/ everything.
The following user(s) said Thank You: Yannis
01 Sep 2020 07:04 #180320 by Yannis
Since i make bench test and my goal is to check motor movement in both directions i will stay with a random STEP SCALE value
i also change some parameters in the servo driver and now i have motor rotation without oscillation
Thanks for the help
01 Sep 2020 07:07 #180321 by Yannis
When i mount the motor in the machine i will calculate more precise this details
01 Sep 2020 07:09 #180322 by Yannis
  • Moderator
  • Moderator
01 Sep 2020 09:10 - 01 Sep 2020 09:11 #180332 by tommylight
OK, then do some more tests with scale at 100 and 200 and 500, see what that does.
Last edit: 01 Sep 2020 09:11 by tommylight. Reason: typo
02 Sep 2020 02:20 #180402 by Yannis
OK
Thanks i will do that
