CMS MAXIMA 4 axis Machine retrofit
20 Jun 2019 00:06 #137344 by Yannis
Replied by Yannis on topic CMS MAXIMA 4 axis Machine retrofit
Replied by bevins Once the remap structure is good
this is what i try to understand
there is your way (python)
and there is a different approach(rack toolchanger)
to make the M6 remap?
20 Jun 2019 05:19 #137358 by andypugh
Replied by andypugh on topic CMS MAXIMA 4 axis Machine retrofit
The remap code can be G-code, Python or any executable file.
If you need to move the axes then it is much easier to use G-code.
In fact i think that you need a very good reason _not_ to use G-code.
The following user(s) said Thank You: Yannis
20 Apr 2020 08:09 #164852 by aluplastvz
Replied by aluplastvz on topic CMS MAXIMA 4 axis Machine retrofit
greeting
to all
Yannis, did you solve your mass i have a similar situation with intermac edge 2300x4000 mm which has 10 + 10 tools but no experience with tool replacement in linux, i also worked with MACH3 but it is not the same procedure.
Do you have an example of how you solved your machine?
greeting
21 Apr 2020 00:14 #164925 by Yannis
Hello
i never get that far
Still trying to connect the servos of the machine
If you search on Youtube you will find several cases ho achieve this task
good luck
21 Apr 2020 01:20 #164928 by aluplastvz
OK thank you
my machine is working
21 Apr 2020 05:51 #164939 by Yannis
Very nice
i have a similar machine working with linuxcnc and 5i25 and 7i77
you can see it there forum.linuxcnc.org/38-general-linuxcnc-q...e-progress?start=110
The following user(s) said Thank You: aluplastvz
22 Apr 2020 04:38 #165059 by Yannis
Hi again
i want to ask something for the 7i76e wiring with the drivers
i will use 3 different type of drivers
1) mitsubishi MR C20A with 200 watt motor
2) AD Tech QS7AA030M with 1.5 kw AD Tech servo
3) DMM DYN4-T01A2-00 with BUALTZ 1.8 kw servo
For the Mitsubishi i manage to connect it with UCCNC Ethernet board
and it was working fine
When i try to connect it with the 7i76e i have motion always in the same direction(when i have similar problem in other boards it was something with ground) the motor is locked
I try wiring like 1) all 6 cables 2)positive connection and negative in 0 volt 3)negative connection and positive to 5 volt
For the AD Tech QS7AA030M and the DMM DYN4-T01A2-00 i will send info when i m ready
22 Apr 2020 04:39 #165060 by Yannis
This browser does not support PDFs. Please download the PDF to view it: Download PDF
  • Moderator
  • Moderator
22 Apr 2020 07:01 #165081 by tommylight
Replied by tommylight on topic CMS MAXIMA 4 axis Machine retrofit
It seems you need stepgen type 1, or up and down pulses, not step/dir.
22 Apr 2020 07:32 #165093 by Yannis
Do you mean that the driver is not capable for position control?
Time to create page: 0.135 seconds
