- Thank you received: 4153
New Project with Mesa 7I96 and THCAD-05
5 years 3 months ago #216584
I had a look at the component source code in git hub.You do need to add the line Phil Suggested:
I think you need to press the Probe Test button in QTplasmac while pressing your switch before the LED will light up in the gui. Make the change above and see how it goes when you press the Probe Test..
I'm sorry, but it seems the example in the docs for ohmic.comp is missing some hal lines in the example. I'll try and get that updated.
I think you are so close, there is no point using your relay just yet. The Plasmac ohmic probing is designed to be used with a couple of relays so you might not just be able to use your circuit without modification.
Replied by rodw on topic New Project with Mesa 7I96 and THCAD-05
If arc-on is going to yellow, then its all wired in OK!Ok with the 3 lines in the custom Hal QTPlasmaC starts When I look at the Hal show for the Ohmic sense values the attached screen shop will explain what happens. The Arc-on changes from red to yellow when the switch is pressed.
net plasmac:ohmic-enable ohmicsense.is-probing
- acourtjester
- Thank you received: 29
5 years 3 months ago - 5 years 2 months ago #216632
by acourtjester
Replied by acourtjester on topic New Project with Mesa 7I96 and THCAD-05
You guys are lucky you in Australia you don't see my happy dance (not good at all
). The probe functions seems to work well, I'm sure I need to make adjustments to the travel. But the probe moves down stops and moves up and stops without touching the limit switch. In the small probe box it has countdown numbers. The Ohmic check still does nothing weather I push it first or after the switch is pressed, the Ohmic indicator does not light ever. That may be another line of code but at this point I don't care. I did have the ohmic probe enable lighted.
I greatly appreciate the the time you all spent helping me with this startup, your perseverance and patience to stay with me is admirable.
Last edit: 5 years 2 months ago by acourtjester. Reason: adding info
5 years 2 months ago #216648
OK, 2 things for you to do. Can you grab a multimeter and a screw driver and adjust the power supply so you are seeing 24.0 volts on the power supply output.
Can you open up the same halshow watch window and monitor the ohmic-on signal when the circuit is closed AND the probe test button is pressed?
When you press the ohmic_test button, does is-probing go yellow? It should.
The Arc-on signal goes on when the voltage is > 24.5 volts which should not happen if the power supply is properly calibrated to output 24.0 volts. You are getting > 26 volts
Just to describe how this works.
The THCAD is monitoring the voltages correctly. When the voltage > 22 volts (ohmic-threshold) AND is-probing is on (yellow) Ohmic-on should go yellow (on). It should stay on until the voltage falls below 1 volt (ohmic-low)
- acourtjester
5 years 2 months ago #216654
by acourtjester
I tried to edit my post twice thanks to snowgoer540 also for your help too.
- acourtjester
5 years 2 months ago #216656
by acourtjester
- phillc54
- Thank you received: 2100
5 years 2 months ago #216759
by phillc54
Replied by phillc54 on topic New Project with Mesa 7I96 and THCAD-05
Sorry Tom, I forgot to post this yesterday. It needs a bit of work but should give you the general idea of what I did.
Time to create page: 0.242 seconds
