- Thank you received: 4153
New Project with Mesa 7I96 and THCAD-05
5 years 3 months ago #216554
Replied by rodw on topic New Project with Mesa 7I96 and THCAD-05
Great progress. Should be good with the unlinkp in the morning!
The following user(s) said Thank You: JoeBean
- acourtjester
- Thank you received: 29
5 years 3 months ago #216556
by acourtjester
Replied by acourtjester on topic New Project with Mesa 7I96 and THCAD-05
Ok with the 3 lines in the custom Hal QTPlasmaC starts When I look at the Hal show for the Ohmic sense values the attached screen shop will explain what happens. The Arc-on changes from red to yellow when the switch is pressed. The Ohmic check does not change when pressed and the switch is pressed. The probe just moves down and up with nothing changing when the switch is pressed.
- phillc54
- Thank you received: 2100
5 years 3 months ago #216557
by phillc54
Replied by phillc54 on topic New Project with Mesa 7I96 and THCAD-05
I am not sure what switch you are referring to.
- acourtjester
5 years 3 months ago #216558
by acourtjester
I have a micro switch acting like the torch tip and metal contacts, switch closes same as torch touching the metal.
- phillc54
5 years 3 months ago #216559
by phillc54
What does the switch connect to?
- acourtjester
5 years 3 months ago #216562
by acourtjester
Time to create page: 0.164 seconds
