- Thank you received: 29
New Project with Mesa 7I96 and THCAD-05
- acourtjester
5 years 3 months ago #216000
by acourtjester
Replied by acourtjester on topic New Project with Mesa 7I96 and THCAD-05
- Thank you received: 4153
5 years 3 months ago #216002
Replied by rodw on topic New Project with Mesa 7I96 and THCAD-05
You need to whatever is set inside your plasma cutter in the calculator. What is it set at? 20:1 is a good setting if your machine accepts it.
The custom.hal file seems to be set up right right for ohmic sensing
- acourtjester
5 years 3 months ago #216003
by acourtjester
Thanks for the files I will use them in the morning, sending the files is a great help as my head is spinning due to my lack of knowledge.
- acourtjester
5 years 3 months ago #216070
by acourtjester
Thanks you so much with the files you changed and adding the Arc Voltage offset and scale I now see the voltage registering on the main screen. With the 50 to 1 and a 9 volt battery it showed 450.
Ohmic sensor does not show any action on screen or in Hal show. does it need a offset value to be entered like the arc voltage did??
I read you can copy the SheetCam tools into the LinuxCNC materials files, if true how do I do it. I have the file for the tools I used and it would be nice to just copy them over.
I have said thanks before but I cannot say how much I appreciate the help you have given this rookie with LinuxCNC. I feel I am very close to making sparks with the new table.
- snowgoer540
- Thank you received: 907
5 years 3 months ago - 5 years 3 months ago #216078
by snowgoer540
Replied by snowgoer540 on topic New Project with Mesa 7I96 and THCAD-05
You do not have ohmic probe checked on the GUI (I did this same thing myself this evening), so I wouldn’t expect ohmic probe to work at this point
give that box a check and report back.
Last edit: 5 years 3 months ago by snowgoer540.
- phillc54
- Thank you received: 2100
5 years 3 months ago #216079
by phillc54
Replied by phillc54 on topic New Project with Mesa 7I96 and THCAD-05
The float switch is connected to:
so check that pin with Halshow.
There is an offset for the float switch in the parameter tabe but that is just to get the coerrect height when you do the probe test set up.
linuxcnc.org/docs/devel/html/plasma/qtpl...tml#qt_initial-setup
The material importer is here:
linuxcnc.org/docs/devel/html/plasma/qtpl...#_material_converter
hm2_7i76e.0.7i76.0.0.input-11
Time to create page: 0.265 seconds
