- Thank you received: 907
New Project with Mesa 7I96 and THCAD-05
- snowgoer540
5 years 3 months ago #215960
by snowgoer540
There's a nice "BACKUP CONFIG" button in the UTILITIES section of the PARAMETERS Tab that does this all for you, and copies all the necessary stuff (in addition to the version number, etc.) for us to make helping you easier.
You can also use it to make a handy backup of the entire QtPlasmaC setup once you get it the way you want it.
A quick read about it can be found here (if you're interested): linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#qt_backup
Replied by snowgoer540 on topic New Project with Mesa 7I96 and THCAD-05
If needed I will copy the whole folder that has the Machine name and zip and attach it here.
- acourtjester
- Thank you received: 29
5 years 3 months ago #215964
by acourtjester
Replied by acourtjester on topic New Project with Mesa 7I96 and THCAD-05
here is the compressed config file from the system today. At this point I have not enabled the second encoder as PhillC had instructed, but will do that today.
Rod the "E" stop works perfectly, homed the axis and hit the "E" stop and both the Power and "E" stop buttons went out. reset the switch and back running Thanks.
- snowgoer540
5 years 3 months ago #215968
by snowgoer540
That looks like the log file.
If you clicked the backup config button, it would have dumped a .tar.gz file in your home directory.
<machine_name>_<version>_<date>_<time>.tar.gz
So something like:
plasma_V1.0.56_21-07-26_10_23_39.tar.gz
So something like:
- acourtjester
5 years 3 months ago #215976
by acourtjester
Sorry rookie mistake
- acourtjester
5 years 3 months ago #215981
by acourtjester
The addition of the encoder selection in the Pncconf to the Hal file made no change to the voltage display. Attaching a 9 volt battery to the Arc voltage input is still only shown in Hal show. I am using a connector to the controller with only the Arc OK and Arc voltage connection. I connect the wires for Arc Ok together and then attach the wires to the 9 volt battery for testing the signals. It is not connected to my Hypertherm, as I do not think that would make any difference.
- Thank you received: 4153
5 years 3 months ago #215986
Replied by rodw on topic New Project with Mesa 7I96 and THCAD-05
Tom, you do not have these settings configured
I did ask earlier but on the back your two THCAD boards, there is a white sticker. Can you post up these two values for both boards please?
I'll have a look at it for you tonight but its 6:30am here so it will be a while...
Arc Voltage Offset = 0
Arc Voltage Scale = 1
Time to create page: 0.167 seconds
