- Thank you received: 29
New Project with Mesa 7I96 and THCAD-05
- acourtjester
5 years 3 months ago - 5 years 3 months ago #215615
by acourtjester
Replied by acourtjester on topic New Project with Mesa 7I96 and THCAD-05
Ok new report, I copied the info to the Custom Hal file, and I then could not start up QTPlasmaC. The error box show a problem with a line in the file I deleted that line. After a few more errors and removing the lines it showed I was back to starting QTPlasmaC I have attached the custom Hal file after the coping in the additional info and an image showing the lines I removed. The Ohmic sensor does not work (I assume the light will light when it does work, image attached). The Float switch does work and show with the float light when activated. I have the THCAD 5 wired to the encoder B is that correct??that is what is shown in the Hypersensing diagram.
Last edit: 5 years 3 months ago by acourtjester. Reason: adding info
- phillc54
- Thank you received: 2100
5 years 3 months ago #215619
by phillc54
Replied by phillc54 on topic New Project with Mesa 7I96 and THCAD-05
Do you have the custom firmware file in the 7i76e?
I "think" it is 7i76e_7i76x1_Dpl.bit
- acourtjester
5 years 3 months ago - 5 years 3 months ago #215687
by acourtjester
- Thank you received: 4153
5 years 3 months ago #215690
Replied by rodw on topic New Project with Mesa 7I96 and THCAD-05
IF you open up halshow under the 7i76e tree, you should see encoder-00. encoder-01, encoder-02
If you only see encoder-00, you have not altered the firmware.
- acourtjester
5 years 3 months ago #215692
by acourtjester
I will check today Thanks
- Thank you received: 5334
5 years 3 months ago #215694
Replied by PCW on topic New Project with Mesa 7I96 and THCAD-05
You could also only have 1 available encoder if you have a
"num_encoders=1" token in the driver command line in your
hal file
hal file
Time to create page: 0.292 seconds
