New Project with Mesa 7I96 and THCAD-05
5 years 3 months ago #213857 by acourtjester
I did a similar way in Mach back in 2018, will do it now with the Linuxcnc wayimage missing /media/kunena/emoticons/smile.png
5 years 3 months ago #213916 by phillc54
5 years 3 months ago #213920 by acourtjester
Thanks Phill
When I get down the road a little more It will be used. I have a laser already mounted on the Y axis with a toggle switch for power but will change when needed.
5 years 3 months ago #213924 by tommylight
That laser should work well in QtPlasmaC.
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#qt_laser
It does, use it daily on 3 machines, soon on 5 just need to find lasers, i am out! :)
5 years 3 months ago - 5 years 3 months ago #215358 by acourtjester
Hi Phillc
Here I am again with my hat in hand, I tried to progress in the next step of configuring for Ohmic sensing and THC.  I tried to copy the info from the manual in to the Hal file and it did not go well.  Either I put it in the wrong place or it conflicted with other lines.  Happy to have the files backed up so am back where I started.  I have attached the INI. Hal and the Show Error file for you to look over, any help is appreciated.  Also what I tried to copy into Hal from the manual.  I did make the change from encoder 2 to 1 Per Rod's info
Thanks Tom
File Name: problems.zip
File Size:6.75 KB
Last edit: 5 years 3 months ago by acourtjester.
5 years 3 months ago #215360 by phillc54
You would be best served having custom hal code in custom.hal rather than your main hal file, that way your main hal file can still be changed by pncconf.
You seem to be missing the loadrt and addf lines.
Time to create page: 0.473 seconds
