- Thank you received: 2100
New Project with Mesa 7I96 and THCAD-05
- phillc54
5 years 3 months ago #216526
by phillc54
Replied by phillc54 on topic New Project with Mesa 7I96 and THCAD-05
It is kinda convoluted, the plasmac.ohmic-probe pin is a generic probe pinput, it can be used by relay (which is what I use) or by ohmic or ohmic3. This pin is fed from a debounce component, the input of which is db_ohmic.in using a signal named plasmc:ohmic-probe.
I thought you were using ohmic3 but you are loading ohmic in custom.hal
linuxcnc.org/docs/devel/html/man/man9/ohmic.9.html
You seem to be missing these two lines from custom.hal:
net ohmic-vel ohmicsense.velocity-in <= hm2_7i76e.0.encoder.01.velocity
net ohmic-true ohmicsense.ohmic-on => plasmac.ohmic-probe
- acourtjester
- Thank you received: 29
5 years 3 months ago #216536
by acourtjester
Replied by acourtjester on topic New Project with Mesa 7I96 and THCAD-05
- Thank you received: 4153
5 years 3 months ago #216541
Replied by rodw on topic New Project with Mesa 7I96 and THCAD-05
Thats great.
If you do the changes to custom.hal that Phill suggests, you should be good.
if you get an error something like "pin is already linked' you might need to add this as right before those 2 lines.
unlinkp plasmac.ohmic-probe
- acourtjester
5 years 3 months ago #216546
by acourtjester
Ok copied the 2 lines to the custom Hal below the other lines talking about the Ohmic sense. Would not start QTPlasmaC did not like the last of the 2 lines removed and started QTPlasmaC fine not change in the operation.
I have attached the error message and the log file.
- acourtjester
5 years 3 months ago #216549
by acourtjester
will do in the morning I did get the error message
- phillc54
5 years 3 months ago #216551
by phillc54
You need to do the unlink line that Rod posted.
Time to create page: 0.231 seconds
