New Project with Mesa 7I96 and THCAD-05
5 years 2 months ago #216844 by PCW
Replied by PCW on topic New Project with Mesa 7I96 and THCAD-05
The relay circuit will have a much higher (say 20X) sense current threshold
than the 24K resistor +THCAD, so if there is very significant leakage current
it would be expected to work better. A lower value sense resistor would
do the same thing while retaining the adjustable threshold , filtering
of the THCAD circuit.
That said, if the relay circuit never doesn't miss
a probe contact event because of high contact resistance, then the
THCAD circuit is unnecessarily complex for that setup.
5 years 2 months ago - 5 years 2 months ago #216845 by snowgoer540
Replied by snowgoer540 on topic New Project with Mesa 7I96 and THCAD-05
That suggests leakage currents as I mentioned. That is if you measure the voltage across the sense resistor with a DVM, you will see that the THCAD is correctly measuring the voltage which is registering the increasing leakage currents.
I am sure that the THCAD is reading correctly.
So if I understand correctly, you are saying that making the resistor value much lower may make that leakage problem go away?
Last edit: 5 years 2 months ago by snowgoer540.
5 years 2 months ago #216846 by PCW
Lowering the sense resistor value doesn't make the the leakage problem
go away it just makes it harder to saturate the measuring circuit
If fact a relay circuit could trip on leakage current, it just has a higher threshold
If you lower the resistance you need to increase the power rating of the sense resistor
to accommodate full plasma voltage or add diode isolation
5 years 2 months ago #216847 by snowgoer540
I'm not sure I understand then what is causing said leakage, other than electrolysis?
5 years 2 months ago #216848 by PCW
That would be my guess
5 years 2 months ago #216850 by snowgoer540
I always figured it had something to do with providing the power supply with the torch voltage. I do know that with the diodes in line in the orientation shown in the diagram, it doesn't happen.
Time to create page: 0.531 seconds
