New day new problem
  • Moderator
  • Moderator
13 Aug 2021 12:07 #217693 by tommylight
Replied by tommylight on topic New day new problem
Missing a
in the AXIS_Z section of the ini file.
13 Aug 2021 16:04 #217707 by rodw
Replied by rodw on topic New day new problem
Ok, The error you are seeing is because you have some inconsistencies in your ini file.
This is what I have in my ini file with home switch at top (in mm)
MIN_LIMIT = -84
MAX_LIMIT = 0.001
HOME_OFFSET = 1.0
HOME_SEARCH_VEL = 10
HOME_LATCH_VEL = 5
HOME_FINAL_VEL = 10
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
HOME_IGNORE_LIMITS = YES
So converting to inches with 4" of travel, it should look similar to
MIN_LIMIT = -4.0
MAX_LIMIT = 0.001
HOME_OFFSET = 0.04
HOME_SEARCH_VEL = 0.5
HOME_LATCH_VEL = 0.25
HOME_FINAL_VEL = 0.5
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
13 Aug 2021 16:19 - 13 Aug 2021 16:41 #217708 by acourtjester
Replied by acourtjester on topic New day new problem
Thanks Tommy's cryptic message made my look intently at the INI file and where the problem was in the upper part the is another max and min, which I was not changing. The 2 locations need to read the same values. It now will not move the Z up at the start of an operation. I set all DROs to zero and I am using the wrench G-code from the examples with a material selected from the list (45XP).  Now I have a floating head switch but it takes about 3 push ups when the the Z is moving down to find the metal surface. After doing that it will move to 0.060 on the DRO and proceed with the G-code to the end without other problems. But at the end the Z DRO is showing -0.0969.  Could the debounce setting for the floating head switch be causing the problem with the switch action.   I looked in the Custom Hal and all the switches are set to 5, not sure if my (bumping up) pushing up on the switch is to fast.
Last edit: 13 Aug 2021 16:41 by acourtjester. Reason: adding info
13 Aug 2021 17:33 #217713 by rodw
Tom, can you share your ini file again? Just so we know what is going on?
13 Aug 2021 18:29 - 14 Aug 2021 00:23 #217717 by phillc54
Replied by phillc54 on topic New day new problem
That normally means that the probe height is too low, probe height is measured from the bottom limit, not the material. How far below the top of the material is your bottom limit?
Last edit: 14 Aug 2021 00:23 by phillc54.
13 Aug 2021 21:05 #217724 by acourtjester
Maybe about an inch, so I think your saying to raise the torch in the holder so there is less of a distance?
13 Aug 2021 23:56 #217731 by rodw
No, just set the probe height to be 3" to start with and then change it down to 2". It must be above the distance below the slats + material thickness. YOu should see it rapid down to probe height and then advance at probe speed
14 Aug 2021 10:46 #217753 by acourtjester
Ok things are getting much better, attached is the INI, Hal, and custom files you requested.  There are 2 sets last chance saloon is the last and seems to have the axis acceleration and velocity working like I think they should.  the other one is mostly the same except for the speed setting.
The problem I had talked about with the floating head switch was my simulating the touching of metal surface by lifting up the torch quickly.  I put some styrofoam on the slates and started a G-code and all worked as expected.  The fact of the Z DRO showing -.0969" after the g-code ran if I set it to zero the next time I ran it it showed 0.00' when it ended the G-code.
The ohmic sensor does not seem to work, but maybe that will be another day.
It has been a long slog and you guys stayed with me and I would like to thank all of you.
File Name: 8-13-21info.zip
File Size:73 KB
14 Aug 2021 18:08 #217776 by phillc54
You don't need to worry about the Z DRO value after a cut. Most folk jog their Z all the way down, set that to zero them never worry about about it again.
14 Aug 2021 18:41 #217779 by acourtjester
understand that is what I did with the other table, thanks for the reply.
Getting down the road with this after much help.
Time to create page: 0.136 seconds
