Tandem Y Axis not working on 7i76E
07 Nov 2023 21:43 #284826 by PCW
Replied by PCW on topic Tandem Y Axis not working on 7i76E
The colors change from yellow to dark red.
Motions joint limit and home switch pins must change from
red  to yellow when activated which = true when activated.
The following user(s) said Thank You: gardenweazel
  • gardenweazel
  • gardenweazel's Avatar Topic Author
  • Elite Member
  • Elite Member
07 Nov 2023 21:55 #284827 by gardenweazel
Replied by gardenweazel on topic Tandem Y Axis not working on 7i76E
Ok, good news. What Tommy recommended worked for the Y-Axis.
It did not work on the Y2-Axis.
@PCW
Is that a correct statement when "-not" is in use?
07 Nov 2023 22:03 #284828 by PCW
The joint home and limit pins are active true which means
they should always be yellow when activated.
Depending on the external sensors you may need to select
the normal or inverted ( -not ) inputs to make this true.
I also suggest you always "watch" the joint pins
to verify the hal connections.
  • gardenweazel
  • Elite Member
  • Elite Member
08 Nov 2023 21:25 #284903 by gardenweazel
In my HAL file, couple of questions.
1. Where are the variables defined that are in use in the HAL file? In documentation? Or is this the actual definition being created?
2. Somehow this doesn't look correct what Tommy mentioned above:
net max-home-z     =>  joint.3.home-sw-in
net max-home-z     =>  joint.3.neg-lim-sw-in
net z-pos-limit     =>  joint.3.pos-lim-sw-in
Is this last line correct?
08 Nov 2023 21:51 #284906 by tommylight
Replied by tommylight on topic Tandem Y Axis not working on 7i76E
Copy-paste error, sorry, should be
net z-neg-limit => joint.3.pos-lim-sw-in
08 Nov 2023 21:54 #284907 by PCW
The LinuxCNC hal pins involved are from motion so
man motion
Will provide documentation on the joint pins for example.
The signal names (like max-home-z ) are arbitrary and created
by the first net command that uses them
Note that I suspect that you have the Z limit wrong as typically
you would use:
net max-home-z     =>  joint.3.pos-lim-sw-in
With a combined home/limit on Z because it's standard
to have the most positive Z position (furthest from the work = most positive)
as the home position. This also means that the Z home search velocity should
be positive.
  • gardenweazel
  • Elite Member
  • Elite Member
08 Nov 2023 23:05 #284909 by gardenweazel
Some success.
Z-Axis homes perfectly the way that it is set up now. I set that to SEQUENCE 0
Different story for Y.
First, it's not synchronizing the 2 joints.
On the Y-Axis it actually senses the switch and reverses like it should.
The Y2-Axis simply continues past the switch and does not reverse.
Attaching files.
  • gardenweazel
  • Elite Member
  • Elite Member
08 Nov 2023 23:48 #284910 by gardenweazel
Adding a Visual.
09 Nov 2023 00:17 #284911 by tommylight
Does not change the fact that it is set up wrong, Z axis 0 should be at the top.
This proves you have direction reversed, so add a - in front of scale value for Z axis, and change the Z homing settings as advised above.
On the picture, the joint 2 switch is active, was the switch triggered when you took the screenshot?
As far as i can see from here, you have joint Y or joint Y2 also reversed, but that requires your reply to above question.
In the mean time, make another config, chose only stepgens, no switches, no homing, nothing but stepgens, select stepgen 2 AND stepgen 3 as Y axis, not tandem, save, start the config, use the keyboard to jog and check:
left arrow = X axis goes left
Right arrow = X axis goes right
Carefully bellow
up arrow = gantry moves away from you
down arrow = gantry moves towards you
Do both Y move in the same direction?
pageUp = z axis moves UP
pageDown = z axis moves down
  • gardenweazel
  • Elite Member
  • Elite Member
09 Nov 2023 14:43 #284944 by gardenweazel
The screen shot was taken after I clicked the orange button. I'll make the changes to the Z-Axis as instructed.
Let me ask, is there a chance that I may have inadvertently miss-wired one of the two Y-Axis motors? I think that is what I am reading into
this mess. I recall wiring one motor initially and then sometime later, I wired all of the remaining motors at the same time with identical wiring.
I did however save my wire configuration and colors so that I could later refer to it.
Time to create page: 0.255 seconds
