Tandem Y Axis not working on 7i76E
11 Nov 2023 19:14 - 11 Nov 2023 22:19 #285123 by Clive S
Replied by Clive S on topic Tandem Y Axis not working on 7i76E
Please delete
Last edit: 11 Nov 2023 22:19 by Clive S. Reason: double posted
11 Nov 2023 19:18 #285124 by Clive S
Are you using jog?
As tandem axis has to be homed first before you can jog
The following user(s) said Thank You: gardenweazel
  • gardenweazel
  • gardenweazel's Avatar Topic Author
  • Elite Member
  • Elite Member
11 Nov 2023 19:23 #285125 by gardenweazel
Replied by gardenweazel on topic Tandem Y Axis not working on 7i76E
TEST files attached as requested.
  • gardenweazel
  • Elite Member
  • Elite Member
11 Nov 2023 19:25 #285126 by gardenweazel
@ Clive S  not using jog period. I'm simply loading up and mashing "HOME ALL".......
11 Nov 2023 20:56 - 11 Nov 2023 21:05 #285131 by Clive S
I only see three joints in your ini file.
Joints = 3
Should there  be 4
Last edit: 11 Nov 2023 21:05 by Clive S.
  • gardenweazel
  • Elite Member
  • Elite Member
11 Nov 2023 21:20 #285132 by gardenweazel
That was a different set of files @Clive.   There was only to be X, Y and Z running naked......
11 Nov 2023 22:03 - 11 Nov 2023 22:27 #285137 by Clive S
Yes. But you stil have 4 joints x-y1-y2-z that is 3 axis
I am confused now
I have just looked through your files and it seems you have only a Y1
With a tandem axis you need Y1 and Y2 in both HAL and INI file
Last edit: 11 Nov 2023 22:27 by Clive S. Reason: added text
  • Moderator
  • Moderator
11 Nov 2023 22:18 #285140 by tommylight
Replied by tommylight on topic Tandem Y Axis not working on 7i76E
Yeah, there are just 3 stepgens in use there, should be 4.
Question, when using this test config and changing from one to the other Y joints, do they both move in the same direction when jogging?
One more thing, no homing with the test setup. Just jogging.
  • gardenweazel
  • Elite Member
  • Elite Member
12 Nov 2023 00:57 #285146 by gardenweazel
Possible PNCCONF issue?
  • Moderator
  • Moderator
12 Nov 2023 01:19 #285147 by tommylight
Yes, PncConf issue, it does not create 2 joints for the same axis, just one.
Does not matter as there is no need for it, except for some initial tests to make sure both tandem drives/motors are spinning the same direction.
I think it's time to make a new config, tandem one with everything set up, but first do
sudo apt update
sudo apt upgrade
maybe there was something iffy in your build.
Time to create page: 0.245 seconds
