Time to setup my lathe with 7i76e
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
25 Dec 2017 14:50 #103592 by tecno
No that was not the line to change.
26 Dec 2017 12:20 #103634 by andypugh
Replied by andypugh on topic Time to setup my lathe with 7i76e - Need help!
Tested pawn.ngc and it works OK, file says S1000 but in reality 610rpm == Where do I adjust this?.
If the error is linear then you can tweak the hm2_5i25.0.7i76.0.0.spindle.scaemax parameter. (I guessed the name, but it is something like that)
  • tecno
  • Platinum Member
  • Platinum Member
26 Dec 2017 12:37 #103638 by tecno
setp hm2_7i76e.0.7i76.0.0.spinout-scalemax 3000
OK, will give this a whirl later on today. Now fullservice on my coffee machine that is high priority ;)
26 Dec 2017 12:42 #103639 by rodw
Coffee is vitally important. Get that fixed first! I had mine serviced earlier in the week!
  • tecno
  • Platinum Member
  • Platinum Member
26 Dec 2017 13:25 #103644 by tecno
OK, tried and this is now very close to correct rpm BUT I cannot command 1824rpm or more
setp hm2_7i76e.0.7i76.0.0.spinout-scalemax 1825
setp hm2_7i76e.0.7i76.0.0.spinout-maxlim 3000
So is there something in INI to be done?
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 3000
# OUTPUT_SCALE = 2500 >>>>>>>> is this something to play with? Copied this from another setup
ENCODER_SCALE = 5000
OUTPUT_MIN_LIMIT = 90 >>>>>>>>this is original min rpm but I take what I can get now 175
OUTPUT_MAX_LIMIT = 3000
  • tecno
  • Platinum Member
  • Platinum Member
26 Dec 2017 13:25 #103645 by tecno
File Name: CNC3000enc...2-26.ini
File Size:3 KB
File Name: CNC3000enc...2-26.hal
File Size:11 KB
26 Dec 2017 14:53 #103655 by andypugh
How are you measuring the RPM?
  • tecno
  • Platinum Member
  • Platinum Member
26 Dec 2017 14:58 #103657 by tecno
Handheld digital meter
  • tecno
  • Platinum Member
  • Platinum Member
26 Dec 2017 15:03 #103658 by tecno
Did a test with manual and max is 2000+ so I will settle for the settings now. This Vfdmotor combo is temporary for now.
Now how to test treading?
26 Dec 2017 15:07 #103660 by andypugh
You can manually start the spindle and just enter a G76 command in the MDI window.
Time to create page: 0.260 seconds
