Work with probe
- Nitram
- Thank you received: 15
19 Aug 2020 10:36 #178697
by Nitram
Replied by Nitram on topic Work with probe
I have been using "Work with probe" for quite a while and am very happy.
My GUI is gmoccapy.
I have found that after I start Linuxcnc, the Probe tab is available and working.
When I probe something, I insert a work offset (from the work offset screen in gmoccapy) by pressing X then Y to set the offset to zero (as the probe parks over the offset position after it finishes probing).
After I insert the offsets in this fashion the probe tab locks out. No matter what I do I cannot enter the probe tab again. I have to restart Linuxcnc to make the tab accessible again.
Can anyone shed any light on to why this behavior is occurring? Could it even be the way gmoccapy reacts to "work with probe"??
Thanks for any insight.
Cheers,
Marty.
My GUI is gmoccapy.
Cheers,
Marty.
- ebartel
24 Aug 2020 11:22 #179223
by ebartel
Replied by ebartel on topic Work with probe
I'm trying to get a probe to work in my machine for the first time. The have the probe screen installed and the probe input I have verified with halshow. The probe I currently do not have in the machine to avoid crashes. When I press any of the probe function buttons I immediately get "Error: User probe error"
I've tried to look through the code and forums for this error to troubleshoot with no luck. Any ideas on how I can troubleshoot?
Full HAL file
INI File
Full HAL file
# Generated by PNCconf at Sat Sep 2 06:06:21 2017
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
#loadrt probe_parport
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=1 num_pwmgens=0 num_3pwmgens=0 num_stepgens=3 sserial_port_0=10xxx "
#setp hm2_5i25.0.watchdog.timeout_ns 10000000
loadrt mux16 names=jogincr
loadrt conv_float_s32 count=1
loadrt scale count=2
loadrt abs count=1
loadrt or2 count=1
loadrt not count=1
loadrt pulseout count=1
# load runtime for e-stops
loadrt estop_latch count=2
addf hm2_5i25.0.read servo-thread
addf jogincr servo-thread
addf hm2_5i25.0.write servo-thread
#addf hm2_5i25.0.pet_watchdog servo-thread
addf scale.0 servo-thread
addf scale.1 servo-thread
addf conv-float-s32.0 servo-thread
addf abs.0 servo-thread
addf or2.0 servo-thread
addf not.0 servo-thread
addf pulseout.0 servo-thread
# add functions for e-stop
addf estop-latch.0 servo-thread
addf estop-latch.1 servo-thread
# external output signals
# --- SPINDLE-CW ---
#setp hm2_5i25.0.gpio.017.is_output true
net spindle-cw hm2_5i25.0.7i76.0.0.spinena
# --- SPINDLE-CCW ---
#setp hm2_5i25.0.gpio.018.is_output true
net spindle-ccw hm2_5i25.0.7i76.0.0.spindir
# --- SPINDLE Speed ---
#setp scale.0.gain 0.035
setp scale.0.gain 0.1
net spindle-speed motion.spindle-speed-out => abs.0.in
net spindle-speed-abs abs.0.out => scale.0.in
net spindle-speed-DAC scale.0.out => hm2_5i25.0.7i76.0.0.spinout
#net spindle-speed-DAC abs.0.out => hm2_5i25.0.7i76.0.0.spinout
#net spindle-speed-scale motion.spindle-speed-out => scale.0.in
#net spindle-speed-DAC scale.0.out => hm2_5i25.0.7i76.0.0.spinout
setp pulseout.0.pulse 10
setp pulseout.0.thread-delay 500
net pulse-spindle-speed pulseout.0.out => halui.spindle.increase
# external input signals
# --- MIN-HOME-X ---
net min-home-x <= hm2_5i25.0.7i76.0.0.input-04-not
# --- MIN-HOME-Y ---
net min-home-y <= hm2_5i25.0.7i76.0.0.input-05-not
# --- ABORT ---
#net abort <= hm2_5i25.0.gpio.018.in
# --- SINGLE-STEP ---
net single-step <= hm2_5i25.0.gpio.019.in
# --- CYCLE-START ---
net cycle-start <= hm2_5i25.0.gpio.020.in
# E-STOP
#GUI Input
net latch-reset iocontrol.0.user-request-enable
net latch0-ok-in iocontrol.0.user-enable-out
net latch0-ok-in => estop-latch.0.ok-in
net latch0-out <= estop-latch.0.ok-out
net latch0-out => estop-latch.1.ok-in
#net latch1-out <= estop-latch.1.ok-out
net latch-reset => estop-latch.0.reset
net latch-reset => estop-latch.1.reset
net latch-out iocontrol.0.emc-enable-in <= estop-latch.1.ok-out
net estop-out estop-latch.1.fault-out
net red-button-estop <= hm2_5i25.0.7i76.0.0.input-06-not
net red-button-estop => estop-latch.1.fault-in
# AXIS X
# Step Gen signals/setup
setp hm2_5i25.0.stepgen.00.dirsetup [AXIS_0]DIRSETUP
setp hm2_5i25.0.stepgen.00.dirhold [AXIS_0]DIRHOLD
setp hm2_5i25.0.stepgen.00.steplen [AXIS_0]STEPLEN
setp hm2_5i25.0.stepgen.00.stepspace [AXIS_0]STEPSPACE
setp hm2_5i25.0.stepgen.00.position-scale [AXIS_0]STEP_SCALE
setp hm2_5i25.0.stepgen.00.step_type 0
setp hm2_5i25.0.stepgen.00.control-type 0
setp hm2_5i25.0.stepgen.00.maxaccel [AXIS_0]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.00.maxvel [AXIS_0]STEPGEN_MAXVEL
net x-pos-fb axis.0.motor-pos-fb <= hm2_5i25.0.stepgen.00.position-fb
net x-pos-cmd axis.0.motor-pos-cmd => hm2_5i25.0.stepgen.00.position-cmd
net x-enable axis.0.amp-enable-out => hm2_5i25.0.stepgen.00.enable
# ---setup home / limit switch signals---
net min-home-x => axis.0.home-sw-in
net min-home-x => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Y
setp hm2_5i25.0.stepgen.01.dirsetup [AXIS_1]DIRSETUP
setp hm2_5i25.0.stepgen.01.dirhold [AXIS_1]DIRHOLD
setp hm2_5i25.0.stepgen.01.steplen [AXIS_1]STEPLEN
setp hm2_5i25.0.stepgen.01.stepspace [AXIS_1]STEPSPACE
setp hm2_5i25.0.stepgen.01.position-scale [AXIS_1]STEP_SCALE
setp hm2_5i25.0.stepgen.01.step_type 0
setp hm2_5i25.0.stepgen.01.control-type 0
setp hm2_5i25.0.stepgen.01.maxaccel [AXIS_1]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.01.maxvel [AXIS_1]STEPGEN_MAXVEL
net y-pos-fb axis.1.motor-pos-fb <= hm2_5i25.0.stepgen.01.position-fb
net y-pos-cmd axis.1.motor-pos-cmd => hm2_5i25.0.stepgen.01.position-cmd
net y-enable axis.1.amp-enable-out => hm2_5i25.0.stepgen.01.enable
net min-home-y => axis.1.home-sw-in
net min-home-y => axis.1.neg-lim-sw-in
net y-pos-limit => axis.1.pos-lim-sw-in
# AXIS Z
setp hm2_5i25.0.stepgen.02.dirsetup [AXIS_2]DIRSETUP
setp hm2_5i25.0.stepgen.02.dirhold [AXIS_2]DIRHOLD
setp hm2_5i25.0.stepgen.02.steplen [AXIS_2]STEPLEN
setp hm2_5i25.0.stepgen.02.stepspace [AXIS_2]STEPSPACE
setp hm2_5i25.0.stepgen.02.position-scale [AXIS_2]STEP_SCALE
setp hm2_5i25.0.stepgen.02.step_type 0
setp hm2_5i25.0.stepgen.02.control-type 0
setp hm2_5i25.0.stepgen.02.maxaccel [AXIS_2]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.02.maxvel [AXIS_2]STEPGEN_MAXVEL
net z-pos-fb axis.2.motor-pos-fb <= hm2_5i25.0.stepgen.02.position-fb
net z-pos-cmd axis.2.motor-pos-cmd => hm2_5i25.0.stepgen.02.position-cmd
net z-enable axis.2.amp-enable-out => hm2_5i25.0.stepgen.02.enable
net z-home-sw => axis.2.home-sw-in
net z-neg-limit => axis.2.neg-lim-sw-in
net z-pos-limit => axis.2.pos-lim-sw-in
# SPINDLE S
#net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
#net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
#net spindle-vel-cmd <= motion.spindle-speed-out
#net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-on <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# ---- SEE Postgui for spindle speed
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward or2.0.in0 pulseout.0.in hm2_5i25.0.7i76.0.0.input-08
net spindle-manual-ccw halui.spindle.reverse or2.0.in1 hm2_5i25.0.7i76.0.0.input-07
net spindle-switch-on or2.0.out not.0.in
net spindle-manual-stop halui.spindle.stop not.0.out
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in hm2_5i25.0.7i76.0.0.input-09 => motion.probe-input
# ---jogwheel signals to mesa encoder - shared MPG---
net joint-selected-count <= hm2_5i25.0.encoder.00.count
# ---mpg signals---
# for axis x MPG
setp axis.0.jog-vel-mode 0
net selected-jog-incr => axis.0.jog-scale
net joint-select-a => axis.0.jog-enable
net joint-selected-count => axis.0.jog-counts
# for axis y MPG
setp axis.1.jog-vel-mode 0
net selected-jog-incr => axis.1.jog-scale
net joint-select-b => axis.1.jog-enable
net joint-selected-count => axis.1.jog-counts
# for axis z MPG
setp axis.2.jog-vel-mode 0
net selected-jog-incr => axis.2.jog-scale
net joint-select-c => axis.2.jog-enable
net joint-selected-count => axis.2.jog-counts
sets selected-jog-incr 0.000000
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
#net estop-out <= iocontrol.0.user-enable-out
#net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
#loadusr -W hal_manualtoolchange
#net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
#net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
#net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
#net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-preparedINI File
# Generated by PNCconf at Sat Sep 2 06:06:22 2017
[EMC]
MACHINE = TRAK_TRM
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EMBED_TAB_NAME=Probe Screen
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} -u python/probe_screen.py -H probe_icons/probe_screen.hal probe_icons/probe_screen.glade
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.200000
DEFAULT_SPINDLE_SPEED=1000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/ebartel/linuxcnc/nc_files
PYVCP = pyvcp-panel.xml
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 0.6
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
438868RY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = /home/ebartel/linuxcnc/configs/TRAK_TRM/macros
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 500000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = TRAK_TRM.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.17
MAX_LINEAR_VELOCITY = 1.67
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 5
FERROR = 0.01
MIN_FERROR = 0.0005
MAX_VELOCITY = 0.3
MAX_ACCELERATION = .65
# The values below sholkvsdjh dpkojncvfsahan MAX_VELOCITY and MAX_ACCELERATION
# hjnm.bhfmg ,k; nklhy If using BACKLASH compensation STEPGEN_M
AXACCEL should be 100% larger.
STEPGEN_MAXVEL = 0.6
STEPGEN_MAXACCEL = 1.5
# these are in nanoseconds
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 4000
STEPSPACE = 4000
STEP_SCALE = -109972.1
BACKLASH = 0.0035
MIN_LIMIT = -1
MAX_LIMIT = 21
HOME_OFFSET = 0.500000
HOME_SEARCH_VEL = -0.3
HOME_LATCH_VEL = 0.1
HOME_FINAL_VEL = -0.300000
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 0
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 5
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 0.3
MAX_ACCELERATION = .65jiky
STEPGEN_MAXVEL = 0.4
STEPGEN_MAXACCEL = 1.3
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 4000
STEPSPACE = 4000
STEP_SCALE = 55019.75
BACKLASH = 0.025
MIN_LIMIT = -0.001
MAX_LIMIT = 14
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 1.667
MAX_ACCELERATION = 2.0
STEPGEN_MAXVEL = 2.1
STEPGEN_MAXACCEL = 2.5
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 6000.0
MIN_LIMIT = -5
MAX_LIMIT = 8.0
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Spindle
[SPINDLE_9]
# Probe
[TOOLSENSOR]
# Absolute coordinates of the toolsetter pad
X = 5
Y = 5
# Absolute Z start search coordinates
Z = 1
# Maximum search distance and direction (sign)
MAXPROBE = -1
# Speed of movements during working in Probe Screen
RAPID_SPEED = 600
# Diameter of toolsetter pad
TS_DIAMETER = 1
# The speed of the reverse rotation of the spindle when measuring the tool diameter
REV_ROTATION_SPEED = 300
[CHANGE_POSITION]
# Abs coordinates tool change point
X = 5
Y = 5
Z = 1
[RS274NGC]
FEATURES=30
SUBROUTINE_PATH = macros
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=manual_change epilog=change_epilog
[PYTHON]
PATH_PREPEND = ./pythonPlease Log in or Create an account to join the conversation.
- Mara2000
- Thank you received: 3
27 Aug 2020 10:23 #179677
by Mara2000
Replied by Mara2000 on topic Work with probe
Hi friends,
I am trying to commissioning probe screen in gmoccapy. Most of function works ok but if I load a program that contains more tools, the probe screen does not work properly.
I uploaded a video to yutube:
Process:
1. Measurement of the tool length (TS height)
2. Measuring the height of the workpiece
3 I start the loaded milling program.
4. The machine go to change position and asks to insert the tool 1
5. The tool lenght is automatically measured on TS sensor position and next g.code program milling starts.
6. After first milling opearation In the g-code, a next tool change is required for the next operation - the Z axis moves upwards and nothing happens anymore. - no message the and machine stops.
Thank you very much for your help.
Process:
- Mara2000
27 Aug 2020 21:54 - 27 Aug 2020 21:55 #179749
by Mara2000
Hi franstrein, could you please send mi your machine configs. I have still problems with M6 Remap ...thank you
Last edit: 27 Aug 2020 21:55 by Mara2000.
- Mara2000
28 Aug 2020 18:07 #179861
by Mara2000
So today I partially solved the problem. If another tool is required in the G-code, the spindle go the exchange position and the machine remains stoped without any message - just click on pause button and a message window pops up to insert another tool! Confirm ok a new tool is measured on toolsettler and the program continues. I will try to tune the postprocessor in fusion 360 for manual change rutine.
The following user(s) said Thank You: tomala89
- harvey
07 Sep 2020 07:29 - 07 Sep 2020 10:28 #181102
by harvey
Replied by harvey on topic Work with probe
My System
OS:Debian GNU/Linux 9 (stretch)
linuxcnc Version: linuxcnc 2.9.0-pre0-2613-g91e5edda7
linuxcnc GUI: Axis
python Version: Python 2.7.13
glade Version:glade3 3.8.6
probescreen V2 from git
I installed the probescreen according to the instructions.
After starting linuxcnc i am able to show the probescreen.
I tested the probing with an elektrical signal to the probe-in pin.
Basically probing works(x, y, z) but i have to adjust the probing parameter.
but
if i try to jog with the implementet jog-buttons nothing nothing happens and i got the following error
File "python/probe_screen.py", line 394, in on_btn_jog_pressed
self.command.jog( linuxcnc.JOG_CONTINUOUS, axisnumber, direction * velocity )
TypeError: integer argument expected, got float
File "python/probe_screen.py", line 407, in on_btn_jog_released
self.command.jog( linuxcnc.JOG_STOP, axis )
TypeError: function takes at least 3 arguments (2 given)
jogging with the Axis-button works
linuxcnc GUI: Axis
but
Last edit: 07 Sep 2020 10:28 by harvey.
- Roguish
- Thank you received: 31
07 Sep 2020 21:07 #181176
by Roguish
Replied by Roguish on topic Work with probe
Could be the INCREMENTS line. you have more than 5 values.
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
try only 5 values.
INCREMENTS = .5mm .1mm .05mm .01mm .005mm
try only 5 values.
- harvey
08 Sep 2020 06:58 #181214
by harvey
OK the error with the increments is fixed
but jogging is still not possible and shows the error in my first post
- RayJr
- Thank you received: 4
13 Sep 2020 16:44 #182022
by RayJr
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
Replied by RayJr on topic Work with probe
the first thing i see is you have two "[RS274NGC]" sections in the ini. There should be only one. So I would cut the lines below the last [RS274NGC] section, and paste the at the end of the first instance of [RS274NGC], then delete the second instance, and save.
Ray
Ray
Albert Einstein
- harvey
14 Sep 2020 09:31 #182068
by harvey
Sorry but i can't find 2 [RS274NGC] sections
Hans-Werner
Hans-Werner
Time to create page: 0.220 seconds
