Work with probe
- MetalByter
02 Apr 2020 18:52 #162478
by MetalByter
Replied by MetalByter on topic Work with probe
Still no luck. I cleaned it up and reinstalled Probe Screen again. Have I missed something?
Now I get an error on startup. I have attached the debug file.
- Thank you received: 7483
03 Apr 2020 00:59 #162518
Replied by tommylight on topic Work with probe
Your attached error file can not be read, it is an openoffice document.
Can you attach the txt file?
- MetalByter
03 Apr 2020 02:35 #162525
by MetalByter
Sorry, here is the .txt file
- MetalByter
07 Apr 2020 01:29 #162996
by MetalByter
Hi there, I really have hit a wall here. Can anyone help?
- Thank you received: 4149
07 Apr 2020 01:52 #163000
Problem from your error log.
I would open the hal file mentioned and comment out the relevant line.
That should allow linuxcnc to run (unless other erorrs)
I would then open halshow and review the pin names. Work out what the correct pin name is, then go back and edit your hal file again to use a valid pin name...
Replied by rodw on topic Work with probe
Debug file information:
./probe_screen.hal:6: Pin 'probe.toolchange-change' does not existI would open the hal file mentioned and comment out the relevant line.
- MetalByter
07 Apr 2020 02:43 #163002
by MetalByter
Thank you rodw, I will try that this evening.
- MetalByter
07 Apr 2020 03:50 #163010
by MetalByter
Yes if I comment those lines out in probe_screen.hal it starts.
the pins and pin names look fine in hal show.
07 Apr 2020 04:09 #163013
I can't help you as I don't use this but maybe post a screen dump of halshow showing the pin names
- MetalByter
07 Apr 2020 04:16 #163015
by MetalByter
Thanks, I will post that in the morning.
- Muscats
13 Apr 2020 01:06 - 13 Apr 2020 08:26 #163831
by Muscats
Is Probe screen able to do Z Touch off on manual tool change? I have looked through the thread and and buttons screen and cannot work out if this is a capability. I currently have Z touch off working based on this implementation 7xcnc.com/software/probing/z-touch-plate/, however it does not appear to be compatable with Probe Screen, as after follwing the Probe screen installation instructions I get an error due to the removal of the Manual Tool change entries in .Hal
Ok, I think I worked that one out, the process involves the "Toolsetter", so does the toolsetter hook up to the same pins as the probe?
It would be so much easier if I could search within a thread.
Replied by Muscats on topic Work with probe
Last edit: 13 Apr 2020 08:26 by Muscats.
Time to create page: 0.371 seconds
