Work with probe
- Sneaky
- Thank you received: 3
16 Mar 2020 03:38 #160388
by Sneaky
Replied by Sneaky on topic Work with probe
Yep, I found the answer in this very thread as I detailed above.
SO MUCH good info here, just gotta find it and sometimes you get blinded to it as you're scrolling through pages and pages of search results.
- MetalByter
30 Mar 2020 03:32 - 30 Mar 2020 15:21 #162056
by MetalByter
Replied by MetalByter on topic Work with probe
Hello, I have the probe screen installed and working well.
But remap M6 and manual tool changes do not work. there is no manual tool change dialogue and M6 Tn makes it
move to the tool change position and then up on the Z axis it is then necessary to pres the program stop button to continue.
I have attached the hal and ini file.
Is there somebody that could guide me through the trouble shooting of this issue, I am not all that familiar with linux.
But have set several machines up with linuxcnc although slowly and with some difficulty.
this one has me stumped.
Last edit: 30 Mar 2020 15:21 by MetalByter. Reason: Added atachments
30 Mar 2020 22:10 #162161
Replied by andypugh on topic Work with probe
The attachments seem to be empty (zero bytes)
Does your hal "loadusr hal_manualtoolchange"?
- MetalByter
30 Mar 2020 23:11 #162181
by MetalByter
Sorry, these should be better.
Where do I see if hal "loadusr hal_manualtoolchange"?
Thanks Andy for trying to help me, it is much appreciated.
And this is a wonderful tool Verser
31 Mar 2020 11:55 #162238
You have the manual tool change section commented-out
Uncomment those lines, and add a line before them to load the manual toolchange component.
Docs:
linuxcnc.org/docs/2.7/html/man/man1/hal_manualtoolchange.1.html
# ---manual tool change signals---
#net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
#net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
#net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
#net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
loadusr −W hal_manualtoolchangeDocs:
- MetalByter
01 Apr 2020 03:54 #162328
by MetalByter
Thanks Andy, They were commented out as per the instructions to install the probe screen. I added the loadusr −W hal_manualtoolchange and uncommented the other 4 lines. I removed the probe screen and will try to load it again in the morning.
The tool change is working again.
01 Apr 2020 21:39 #162383
I don't know why probe-screen says to comment the lines. It might be for a very good reason. Perhaps probe-screen expects to do it itself?
- MetalByter
01 Apr 2020 22:01 #162385
by MetalByter
The tool change seems to be working and probe screen seems to load.
Linuxcnc starts and I can home my machine now but probing is not working.
I will be able to post my ini and hal files in a few minutes.
- MetalByter
01 Apr 2020 22:41 #162394
by MetalByter
Yes probe screen is supposed to do the tool change.
If I comment out EMBEDDED _TAB and EMBEDED_TAB_COMMAND in the display section and uncomment tool change in the hal file
tool change works. otherwise the probe screen comes up but no tool change.
- ikkuh
- Thank you received: 48
02 Apr 2020 08:52 #162434
by ikkuh
Maybe it is because for example Gmoccapy asks you to add similar lines for their own toolchange routines.
Replied by ikkuh on topic Work with probe
Time to create page: 0.187 seconds
