- Thank you received: 1481
Work with probe
4 years 10 months ago #229554
Replied by Todd Zuercher on topic Work with probe
To calibrate your 3-d probe I would mill a piece to a known height, dimension, and location. Then probe that, and adjust your probe settings until you get probing results that match the known piece.
The following user(s) said Thank You: ikkuh
- myval
- Thank you received: 7
4 years 10 months ago #229709
by myval
Replied by myval on topic Work with probe
That is not going to give me much since you always touch on the bottom of the ball. That can not give different result then the height of the block.
4 years 10 months ago #229725
I was suggesting milling the sides of the block as well, not just the top. So that you can calibrate the sides of the probe.
- myval
4 years 10 months ago #229727
by myval
Right ok, for sides I have precision ground calibrated cal rings. We are fairly well metrologically setup. The only problem was not so calibrating the Z height of the probe but the basically Z position in space in relation to any other tools.
4 years 10 months ago #229738
The idea was to mill the calibration bock with a tool that had been touched off on you tool touch probe, so that its height was known. After milling the 5 faces of the block, then all 5 faces positions would be known. Even if you don't know the precise diameter of the milling tool, it can be calculated by measuring the finished size of the block.
I don't think having a precision ground block helps you, unless your probe is mounted in the spindle and you know it's tip is concentric to your tooling, because you wouldn't know the blocks precise location,
- myval
4 years 10 months ago #229746
by myval
Ok I actually do something similar to get the exact tool diameter. I machine circle with roughly measured tool then measure the exact diameter result and tweak the tool diameter in my tool library.
The precision ground ring actually is for calibrating the ball end dia on the probe, touch it in x+ x- y+ y- and get exact ball dia. My probe is mounted in the spindle but this works for probe mounted anywhere really.
You just gave me another idea (or at least it just clicked in) why don't I use this technique to work out my probe Z offset issue?
I can surface a piece then probe it and this will give me the probe to the tool Z difference (really what I was worried about from the start).
Since I will have the tool touched off on the tool setter this will give me exact difference between probe and tool (tool setter trip point actually) and any other tool touched off on the tool setter will have the same mathematics (complex math +- few mm) applied to it.
And I can even move mathematically my 0 point up so every tool length will have the same sign. Hey welcome back brain.
yeah I think by brain just klick into gear. If that is the way you guys kept saying I finally got it.
Time to create page: 0.433 seconds
