Ok your path is different:
Go to ~/linuxcnc/configs/Router
type ls and you should see all the files just like in your screenshot.
then try
linuxcnc Router.ini
and that should start your machine config.
[edit]
As for what you're seeing:
"CLinB0" is this in your custom_postgui.hal : net remote-z-axis-touchoff classicladder.0.in-00 <= pyvcp.z-axis-touchoff
"CLinB1" is: net mode halui.mode.is-mdi => classicladder.0.in-01
"CLinB2" is: #net in_pos motion.motion-inpos => classicladder.0.in-02 (so this will never turn to true because it's commented out!)
"CLoutB0" is: net z-touchoff classicladder.0.out-00 => halui.mdi-command-00
"CLoutB1" is: net z-zero classicladder.0.out-01 => halui.mdi-command-01
"CLoutB2" is: #net rapid-away classicladder.0.out-02 => halui.mdi-command-02 (which is also commented out for some reason)
The whole diagram is fairly easy to understand. Its just like an electric circuit:
-| |- is a normally open switch, so it needs to go TRUE to let the signal pass from left to right.
-|/|- is a normally closed switch, so it needs to be FALSE to let the signal pass from left to right.
-( ) is an output
-(S) means if the signal reaches it all the way from the left side of the window is sets the corresponding output to TRUE
-(R) means if the signal reaches it all the way from the left side of the window it set the corresponding output to FALSE
then you also have some timer blocks that create delays and such.
The nice thing is you can watch what happens as you press the buttons.
Have a look if those lines in your "custom_postgui.hal" should really be commented out (the leading #).
