Touch Plate Explanation please
5 years 11 months ago - 5 years 11 months ago #190669 by Aciera
Hang on I found an error in the config I posted I will post another shortly...
[edit]
Ok, so again:
1- DELETE your folder "Router" in the folder "config".
2- check that the folder "config" does NOT contain a folder "Router" anymore
2- Unzip the attached "Router.zip" into your folder "config"
3- Check if the folder "config" contains a folder "Router" again.
4- start Router.ini from the terminal.
5- report any errors
Here is the "Router.zip" to unzip into your "config" folder after you have completed steps 1 and 2:
File Name: Router_2020-11-30.zip
File Size:7.83 KB
Last edit: 5 years 11 months ago by Aciera.
5 years 11 months ago #190673 by shortcircuit48
Thanks again and progress. I had spent some time, again, cleaning out and then created a new config. Followed your instructions although I do not know how to start from terminal. and just used the desktop icon. Linuxcnc booted up and touchoff now working so nearly all ok.
I am trying to find a way to start my spindle. I have used the Hal Watch and this changes when I activated on/off. Sould I have changed a pin in the Stepconfig?
5 years 11 months ago #190675 by Aciera
What breakout board are you using on your parallel port?
5 years 11 months ago - 5 years 11 months ago #190678 by shortcircuit48
It is a Chineeze BoB with "MACH3 Interface board"
It has connections for 0>10vSpeed spindle and PWM
Last edit: 5 years 11 months ago by shortcircuit48.
5 years 11 months ago #190681 by Aciera
Any information as to which pin the BOB wants the pwm (spindle speed) signal from the parallel port?
This one?
5 years 11 months ago - 5 years 11 months ago #190682 by shortcircuit48
Yes, identical. My inverter can take an analogue input or RS485
Time to create page: 0.116 seconds
