Aha, then your pin assignments are wrong.
This is what you have in "Router.hal" Lines 42 to 63:
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
setp parport.0.pin-03-out-invert 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
setp parport.0.pin-05-out-invert 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net astep => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net adir => parport.0.pin-09-out
net spindle-cw => parport.0.pin-14-out
net spindle-pwm => parport.0.pin-16-out
net xenable => parport.0.pin-17-out
net estop-ext <= parport.0.pin-10-in
net probe-in <= parport.0.pin-11-in-not
net home-x <= parport.0.pin-12-in
net home-y <= parport.0.pin-13-in
Your BOB wants the PWM (Spindle speed) signal on Pin1 so you need to assign the signal "spindle-pwm" to pin1.
So do this:
change line 42 to:
net estop-out => parport.0.pin-16-out
change line 58 to:
net spindle-pwm => parport.0.pin-01-out
Save and run.
