Touch Plate Explanation please
4 years 11 months ago #226557 by shortcircuit48
File Name: Router_2021-11-15.ini
File Size:2.61 KB
I think I posted the wrong Router.ini file. Will try again.
4 years 11 months ago - 4 years 11 months ago #226593 by shortcircuit48
After a good bit more trial and error I find I can home Z. When I attempt to home X&Y the display still remains red and the value increases and I assume if the joints were connected would run.(No limit switches used) Attempting to probe has no effect.
Hope this might provide a clue.
Edit   This is garbage
Last edit: 4 years 11 months ago by shortcircuit48.
4 years 11 months ago #226924 by shortcircuit48
I gave up. Back to the roll up fag paper, that's advanced technology
The following user(s) said Thank You: ikkuh
4 years 11 months ago #227318 by shortcircuit48
I hate getting beat so I came back as it did work, so no reason why it should not work again. I have gone through the configuration several times but just not getting there. I have the touch button displayed and it does appear to operate. I assume that when activated is should start the "MDI" commands but nothing happens? Am I missing something in the "Advanced Configuration Options"?
I am very much a senior citizen(76) and finding my mind is not as sharp as it used to be so help is appreciated.
4 years 11 months ago #227345 by andypugh
Gmoccapy goes it's own way where touch plates are concerned, but it is documented:
linuxcnc.org/docs/2.8/html/gui/gmoccapy....uto-tool-measurement
I haven't read back through all 5 pages to see if that link has already been posted. If it has, then sorry.
The following user(s) said Thank You: shortcircuit48
4 years 11 months ago #227635 by shortcircuit48
Andy, I thank you for your reply. I have looked at the link you have provided and attempted numerous "fixes" to no avail.
My initial probe problem was resolve at page 3 by ACIERA who provided a INI file and Gladevcp folder which resolved the problem. However I attempt to replicate the installation and am not making any progress. The touch button appears to work but does not activate the MDI commands although I can enter them manually. Not sure where I should be looking so any direction would be much appreciated.
Time to create page: 0.070 seconds
