Update help ---- PoKeys No moore
- tecno
- Thank you received: 127
26 Jan 2021 08:16 #196616
by tecno
Replied by tecno on topic Update help ---- HAL issues
File is in GB_2speed folder
26 Jan 2021 08:25 #196617
Replied by andypugh on topic Update help ---- HAL issues
It probably needs to be recompiled / installed.
sudo halcompile --install GB_2Speed.comp
(or similar)
(or similar)
The following user(s) said Thank You: tecno
- tecno
26 Jan 2021 08:29 #196618
by tecno
Will give it a whirl
ps. new Asus VT168 installed on milling machine replacing the old faulty monitor.
Very nice monitor and Touch works = happy camper
- tecno
26 Jan 2021 09:30 #196624
by tecno
Halcompile did the trick, thank you Andy
- tecno
26 Jan 2021 09:42 #196626
by tecno
Next problem = No MPG
HALSHOW
All signal from MPG is OK so there must be something not connected properly in HAL after script from 2.7 to 2.8
HALSHOW
26 Jan 2021 17:57 #196686
Not the actual source of the problem, but you are using 7i73 GPIO pins to drive a software encoder counter.
It would make a lot more sense to use the 7i73's built-in encoder counting system. You even have the encoder wired to the correct 7i73 pins (8 and 9 for enc0)
- tecno
27 Jan 2021 02:45 #196715
by tecno
OK.
So what kind of remedy can we find to this? Was working flawlessly in 2.7.
I am all open for a solution and grateful fore all help.
27 Jan 2021 06:51 #196749
Well, it will work but it is slightly wasteful of CPU and won't count accurately if you move the jogwheel fast.
What isn't working? If you poke around with halmeter does the encoder counts count? Do that count get sent to the axis and joint jog counts pins? Do you see the jog-enable pins operate properly?
- tecno
27 Jan 2021 07:00 #196751
by tecno
forum.linuxcnc.org/9-installing-linuxcnc...sues?start=80#196626
No axis movement. But I am willing to *update* to get better performance.
27 Jan 2021 08:37 #196768
Can you answer the questions about counts and enables?
Time to create page: 0.156 seconds
