Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
- Thank you received: 3739
19 Oct 2023 18:46 #283313
To start your project, please fork this repository github.com/LinuxCNC/linuxcnc-live-build and checkout the bookworm branch
eg git checkout bookworm
This has had my repository that I used to build this iso merged into it.
github.com/rodw-au/linuxcnc-live-build
There is a lot of activity right now in preparation for the 2.9.1 release
The ISO from this installer are now on the linuxcnc web site so we are getting there!
www.linuxcnc.org/iso/
Replied by rodw on topic Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
You don't say how you have created your live build environment.I am trying to run my own live-build on a bookworm install, but get this error:
Errors were encountered while processing:
linux-image-6.1.0-13-rt-amd64
linux-image-rt-amd64
Any ideas?
- probotix
19 Oct 2023 20:57 - 19 Oct 2023 21:00 #283317
by probotix
Replied by probotix on topic Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
Thats exactly what I did... checked out the bookworm branch.
git clone github.com/LinuxCNC/linuxcnc-live-build
cd linuxcnc-live-build
lb config
sudo su
lb build
lb config
sudo su
lb build
Last edit: 19 Oct 2023 21:00 by probotix.
19 Oct 2023 21:24 #283320
I have no idea but it worked for me in the last day or so.
- Thank you received: 6843
19 Oct 2023 22:07 #283326
Replied by tommylight on topic Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
That is a pretty old ISO of Debian BookWorm, the 12.2 ISO has no such issues.debian 12 raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned error exit status 1
19 Oct 2023 22:21 #283327
I think the installer has been rebuilt on Debian 12.2 now.
robh did say he was doing an upgrade when he had his problem. So it must have been an earlier install.
In any case once, you do a sudo apt upgrade you will be upgraded to 12.2 plus any additional security patches.
Its hard to keep track of things when there are more than one user with issues on the on thread!
19 Oct 2023 22:47 #283332
Probably since we get this rpi issues about once a week or two, it was much often before.I think the installer has been rebuilt on Debian 12.2 now.
- probotix
20 Oct 2023 14:48 #283357
by probotix
I am on a brand new install of Debian 12.2. Did the full upgrade to latest then followed forking of the repository and checking out the bookworm version.
What should my apt sources be?
20 Oct 2023 19:14 #283379
The installer should set the repositories up correctly. (main contrib non-free non-free-firmware) provided you have an internet connection. It seems to be dynamically generated.
refer to :
auto/config (debian are meant to be set up here but it needs overriding)
config/archives (various files end up in different apt folders based on their name for chroot and binary)
config/includes.installer/preseed.cfg (override here)
config/hooks/normal (510,520,530)
The hooks are used to add some third party repos but not install anything from them
refer to :
27 Oct 2023 09:53 #283901
Yay! 2.9.1 is officially released. Grab your .ISO from here
linuxcnc.org/iso/linuxcnc_2.9.1-amd64.hybrid.iso
I will update the download URL in the first post once I gather the strength to tackle the forum editor!
Also note that Linuxcnc 2.9.1 is now in Debian Unstable which means in about 5 days, it will be in Debian 13 (Trixie)
Very cool!
Very cool!
The following user(s) said Thank You: JohnnyCNC
- JohnnyCNC
- Thank you received: 106
29 Oct 2023 15:13 #284031
by JohnnyCNC
Replied by JohnnyCNC on topic Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
I am trying to install using the image linked above. The image is on a USB drive. It boots. I select start installer.
I see some errors go by that mention:
mount: mounting /dev/sda on /media failed.
mount: mounting /dev/sda1 on /media failed.
mount: mounting /dev/sda2 on /media failed.
mount: mounting /dev/sda3 on /media failed.
I go through the country and language selections and then I get the error that "Your installation media couldn't be mounted. When installing from a CD-ROM, this probably means that the disk was not in the drive. If so you can insert it and try again."
I did find that if I unplug the USB drive and plug it back in and have it retry mounting the drive it will continue the install process.
Time to create page: 0.101 seconds
