Ethercat installation from repositories - how to step by step
12 Sep 2024 17:43 #310018 by bertoldo
seems to be exactly where I am at the moment...
12 Sep 2024 20:34 #310032 by jjdege
sorry,
here they say that the drivers are OP and the engines move,
you're on the right track then
14 Sep 2024 14:41 #310149 by Henk
HI
A couple of weeks ago i installed a the iso from rodw's google drive, worked fine, no problems.
This time, i tried the one from the downloads page, and also again the google drive one, but i get these errors. I have seen similar errors in this thread, but the sollutions are either not clear or doesnt work for me.
i ran apt update, and also apt upgrade as per the sticky, but these errors appear when i try installing linuxcnc-ethercat. I ran the script from forum.linuxcnc.org/ethercat/53785-instal...-repositories#309963
but still get errors as seen below
linuxcnc@linuxcnc:~$ sudo apt install linuxcnc-ethercat
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages were automatically installed and are no longer required:
  linux-headers-6.1.0-23-amd64 linux-headers-6.1.0-23-common
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  autoconf autoconf-archive automake autotools-dev ethercat-dkms ethercat-master libethercat libltdl-dev libtool m4
Suggested packages:
  gnu-standards autoconf-doc libtool-doc gfortran | fortran95-compiler gcj-jdk m4-doc
The following NEW packages will be installed:
  autoconf autoconf-archive automake autotools-dev ethercat-dkms ethercat-master libethercat libltdl-dev libtool linuxcnc-ethercat m4
0 upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,415 kB/5,387 kB of archives.
After this operation, 86.6 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Ign:1 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-dkms 1.6.1.g419f621-1+8.3
Ign:2 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-master 1.6.1.g419f621-1+8.3
Ign:3 http://opensuse.mirror.liquidtelecom.com/repositories/science%3A/EtherLab/Debian_12 ./ linuxcnc-ethercat 1.40.0.g8a607c0-0
Err:1 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-dkms 1.6.1.g419f621-1+8.3
  Could not connect to opensuse.mirror.liquidtelecom.com:80 (2c0f:fe40:8001:10::1). - connect (101: Network is unreachable) Could not connect to opensuse.mirror.liquidtelecom.com:80 (197.155.77.1), connection timed out
Err:2 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ ethercat-master 1.6.1.g419f621-1+8.3
  Unable to connect to opensuse.mirror.liquidtelecom.com:http:
Err:3 http://opensuse.mirror.liquidtelecom.com/repositories/science%3A/EtherLab/Debian_12 ./ linuxcnc-ethercat 1.40.0.g8a607c0-0
E: Failed to fetch http://opensuse.mirror.liquidtelecom.com/repositories/science%3A/EtherLab/Debian_12/all/ethercat-dkms_1.6.1.g419f621-1%2B8.3_all.deb  Could not connect to opensuse.mirror.liquidtelecom.com:80 (2c0f:fe40:8001:10::1). - connect (101: Network is unreachable) Could not connect to opensuse.mirror.liquidtelecom.com:80 (197.155.77.1), connection timed out
E: Failed to fetch http://opensuse.mirror.liquidtelecom.com/repositories/science%3A/EtherLab/Debian_12/amd64/ethercat-master_1.6.1.g419f621-1%2B8.3_amd64.deb  Unable to connect to opensuse.mirror.liquidtelecom.com:http:
E: Failed to fetch http://opensuse.mirror.liquidtelecom.com/repositories/science%3A/EtherLab/Debian_12/amd64/linuxcnc-ethercat_1.40.0.g8a607c0-0_amd64.deb  Unable to connect to opensuse.mirror.liquidtelecom.com:http:
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
E: Conflicting values set for option Signed-By regarding source http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/ ./: /etc/apt/trusted.gpg.d/science_EtherLab.gpg != /etc/apt/trusted.gpg.d/science_EtherLab.gpg.key.binary.gpg
E: The list of sources could not be read.
Any idea how to fix this?
Henk
16 Sep 2024 11:35 #310249 by bertoldo
hello dear.
try it.
'unistall chave gpg
sudo rm /etc/apt/trusted.gpg.d/science_EtherLab.gpg
sudo rm /etc/apt/trusted.gpg.d/science_EtherLab.gpg.key.binary.gpg
'reinstall it
wget -O - download.opensuse.org/repositories/scien...ebian_12/Release.key | sudo apt-key add -
'update
sudo apt update
'install again
16 Sep 2024 18:42 #310277 by AndyDM01
so I got stuck, still can't get any movement , and yes i tried everything , someone please explain what are the basics to get an operational system...
from absolute zero ... in what order to do stuff ... i am sure i did something wrong and just got stuck so i will restart from zero but ... please please please someone can tell me the order to do stuff ... i just erased everything from the harddisk and have option to start from zero ...
16 Sep 2024 19:33 #310281 by bertoldo
hello!
I went through this too! I'm finishing a document with files... very neatly so there are no doubts... when I finish I'll post it here
17 Sep 2024 17:38 #310325 by Henk
HI bertoldo
It doesnt work.
linuxcnc@linuxcnc:~$ wget -O - download.opensuse.org/repositories/scien...ebian_12/Release.key | sudo apt-key add -
--2024-09-17 19:36:19--  http://download.opensuse.org/repositories/scien...ebian_12/Release.key
Resolving download.opensuse.org (download.opensuse.org)... 195.135.223.226, 2a07:de40:b250:131:10:151:131:30
Connecting to download.opensuse.org (download.opensuse.org)|195.135.223.226|:80... Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
connected.
HTTP request sent, awaiting response... 404 Not Found
2024-09-17 19:36:20 ERROR 404: Not Found.
gpg: no valid OpenPGP data found.
also when i try to update i get the following
linuxcnc@linuxcnc:~$ sudo apt update
17 Sep 2024 19:16 #310339 by AndyDM01
just some basic guidelines to get into the ethercat side off linuxcnc would mean a lot to the noobs
17 Sep 2024 20:25 #310345 by bertoldo
I'm almost done with mine... now I just need to change from CNC 3-axis to SCARA... which isn't easy for me because it's my first time. So I'll provide how I did it... with videos etc... I haven't faced that error of yours. I don't know if it's allowed for the moderator to suddenly make a WhatsApp group, which is easier and faster...
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
18 Sep 2024 09:23 #310358 by rodw
I shared this script for when the ethercat repo needs reinstalling
forum.linuxcnc.org/ethercat/53785-instal...thercat-repositories
The following user(s) said Thank You: AndyDM01, bertoldo
Time to create page: 0.830 seconds
