EtherCAT driver for a 6 axis robot
4 years 5 months ago #242497 by TheRoslyak
Replied by TheRoslyak on topic EtherCAT driver for a 6 axis robot
Fine.
Now, if I were you, I would create an xml file that linuxcnc can display. - I think it's definitely needed
4 years 5 months ago - 4 years 5 months ago #242499 by ftree
Replied by ftree on topic EtherCAT driver for a 6 axis robot
Some of the steps / guides here are proving informative
sticky in this section
forum.linuxcnc.org/ethercat/45336-etherc...-step-by-step#237098
And also
gist.github.com/Bouni/8b4532d0bdf012bd83c65d3eb62f8aa2
Last edit: 4 years 5 months ago by ftree.
4 years 5 months ago #242501 by db1981
Replied by db1981 on topic EtherCAT driver for a 6 axis robot
hmm, what for this case is needed is an direct cyclic control of the joint motor amps, like cyclic synchronus position or velocity mode. without an inserted controller from the robots motion system.
The joint indexs that TheRoslyak marked in his picture are only feedback information from the robot to ethercat. controlling at this firmware is reached through the motion command block with the underlaying motion que. And this sadly is not rt controllable....
4 years 5 months ago - 4 years 5 months ago #242505 by ftree
EtherCAT interface appears to support MotionCommandID with six arguments (for each joint?). Here are two - many others available. See table 7 in programming manual. "List of MotionCommandID numbers"
ID=6 MoveJoints 6 arguments in degrees ID=23 MoveJointsVel 6 arguments in degrees / sec
4 years 5 months ago #242506 by TheRoslyak
And I did not say that these registers are needed for control.
For control need move command (for example 1 - is line 2 - arc 3 - spline and etc)
And sub index ( is x ,y, z ,etc)
In any case, if you do it through linuxcnc, Need combinations of mux, dmux and etc
4 years 5 months ago - 4 years 5 months ago #242510 by ftree
The only "cyclic" modes (velocity mode) are
MoveJointsVel
MoveLinearVelWrf
MoveLinearVelTrf
These can be sent evey cycle with MoveID=0, SetPoint = 1. To stop the robot send SetPoint=0
Would a velocity mode with position feedback from each joints encoder be such a bad thing? Robot timestamp,  World Reference,  Tool Reference and Robot Base Reference are available data on the TxPDOs in various data forms.
Time to create page: 0.146 seconds
