- Thank you received: 10
EtherCAT driver for a 6 axis robot
- ftree
4 years 3 months ago #248049
by ftree
Replied by ftree on topic EtherCAT driver for a 6 axis robot
Made some good progress today starting the application with vismach. I may not have the rotates and translates right yet but close.
github.com/djsftree/linuxcnc-ethercat/tree/master/wip-meca500
- ftree
4 years 3 months ago #248247
by ftree
I've split the project into two repositories now
Meca500 LinuxCNC EtherCAT HAL Driver
Meca500 LinuxCNC (currently using generic EtherCAT driver xml)
github.com/djsftree/linuxcnc_meca500
- ftree
4 years 3 months ago #248341
by ftree
Hi @db1981. Are you available to assist? Are you on the Discord server?
- db1981
- Thank you received: 276
4 years 3 months ago #248431
by db1981
Replied by db1981 on topic EtherCAT driver for a 6 axis robot
hi,
i am very out of time at the moment.
I'm involved in two bigger projects, which have to produce asap.
But now we do redesign/recoding on the construction site, caused by parts availibility.
Maybe i will get a few hours the next week....
The following user(s) said Thank You: ftree
- ftree
4 years 3 months ago #248624
by ftree
Thanks! if you have the time it would be greatly appreciated.
To recap. I’m working on an internal project involving the Mecademic Meca500 6 axis robot
www.mecademic.com/en/meca500-robot-arm
Here’s some useful links so far
Cyclic data that can be sent to the robot
cdn.mecademic.com/uploads/docs/meca500-r...4.pdf#subsection.3.4
Cyclic data received from the robot
cdn.mecademic.com/uploads/docs/meca500-r...4.pdf#subsection.3.5
Communicating over ethercat
cdn.mecademic.com/uploads/docs/meca500-r...al-8-4.pdf#section.4
ethercat XML file
github.com/djsftree/linuxcnc_meca500/blo...meca500-ethercat.xml
custom homing comp skeleton
github.com/djsftree/linuxcnc_meca500/blo.../meca500_homing.comp
I would welcome a review of the initial skeleton code and any suggestions to the potential homing architecture for this particular robot.
The robot has its own internal mechanism for homing once the robot is activated.
-- set
ctrl.activate 1
ctrl.deactivate 0
-- wait for
status.activated 1
status.busy 0
-- set
ctrl.home 1
j0, j1, j2 rotate 3.6deg
j3, j4 rotate 7.2deg
j5 rotates 12deg
above joints rotate back the same amout
this procedures takes 3 seconds to complete
joint position during homing is available on ethercat encoder.a1 thru a6
-- wait for
status.homed 1
status.busy 0
-- homed and ready to accept motion commands
Best regards,
David
ethercat XML file
-- set
ctrl.activate 1
ctrl.deactivate 0
-- wait for
status.activated 1
status.busy 0
-- set
ctrl.home 1
j5 rotates 12deg
-- wait for
status.homed 1
status.busy 0
Best regards,
David
Time to create page: 0.513 seconds
