- Thank you received: 10
EtherCAT driver for a 6 axis robot
- ftree
4 years 5 months ago - 4 years 5 months ago #242527
by ftree
Replied by ftree on topic EtherCAT driver for a 6 axis robot
"Kinematics, singularys etc. are another chapter....."
I may use RobotDK to work out best use of the axes and "post process" to pre-calculated G-code. Meca500 kinematics supported.
Last edit: 4 years 5 months ago by ftree.
- ftree
4 years 5 months ago - 4 years 5 months ago #242529
by ftree
WIP attached.
Well that's neat. You can set up to four "custom dynamic data tables" to be sent to the EtherCAT master such as real-time
joint position
joint torque
3-axis accelerometer
end effector pose (tool or world referenced)
and many others!
joint position
joint torque
and many others!
- ftree
4 years 5 months ago - 4 years 5 months ago #242792
by ftree
I've seen some examples of using a ddt to prepare velocity and acceleration. Still trying to understand if that's required. What signals need moving around between the motion controller, the pid and the meca500 encoders. Also to understand if any dataformat comversion needs to take place.
I may need to draw a chart. Requires coffee. Back soon.
- ftree
4 years 5 months ago - 4 years 5 months ago #242932
by ftree
Taking a look at linuxcnc-ethercat now
- ftree
4 years 5 months ago - 4 years 5 months ago #243085
by ftree
I have forked linuxcnc-ethercat with a view to add Meca500 support
github.com/djsftree/linuxcnc-ethercat/
- ftree
4 years 5 months ago - 4 years 5 months ago #243205
by ftree
I've been reviewing the other hardware in src
If anyone is able to review the direction i'm going in I would be very grateful.
github.com/djsftree/linuxcnc-ethercat/commits/master
Time to create page: 0.169 seconds
