EtherCAT driver for a 6 axis robot
4 years 3 months ago - 4 years 3 months ago #247938 by db1981
Replied by db1981 on topic EtherCAT driver for a 6 axis robot
yes, checking the whole ec-bus is an good thing.
this is a part from out standart safty/error handling comp, this comp works together with the safty-plc in the cabinet.
ec_slaves_responding_ok = (ec_slaves_responding == ec_slaves); if (!ec_slaves_responding_ok) {   emc_enable_out = 0;   if (data.last_ec_slaves_responding_ok) {     rtapi_print_msg(RTAPI_MSG_ERR, "EtherCAT: Not all %d slaves responding!\n",    ec_slaves); }} data.last_ec_slaves_responding_ok = ec_slaves_responding_ok;  if (!ec_link_up) {   emc_enable_out = 0;   if (data.last_ec_link_up) {     rtapi_print_msg(RTAPI_MSG_ERR, "EtherCAT: Link down!\n"); }} data.last_ec_link_up = ec_link_up;  if (!ec_all_op) {   emc_enable_out = 0;   if (data.last_ec_all_op)   {rtapi_print_msg(RTAPI_MSG_ERR, "EtherCAT: Not all slaves in OP mode!\n"); }} data.last_ec_all_op = ec_all_op;
Last edit: 4 years 3 months ago by db1981. Reason: hating windows formatting
4 years 3 months ago #247940 by db1981
[quote]I don't know if this is practicable in the whole system but my way of implementation would be:[/quote] This is where my experience and knowlege of the workings of lcnc falls off a cliff.  If you're available for contract work let me know.  The resulting work would be open source.
with whole system, i am thinking about the safty regulations, hardware design of the complete machine.
this is my daily business, which country you are living?
4 years 3 months ago #247956 by ftree
Replied by ftree on topic EtherCAT driver for a 6 axis robot
Nottingham, UK.
4 years 3 months ago - 4 years 3 months ago #247997 by ftree
In the meantime I've tidied the folder and now attempting to get the vismach starting, at least. I have two versions of DH/DH(modified) to try for the kins. Working on the best way to orientate and save the obj links too and set up correct WRF/HOME placement.
github.com/djsftree/linuxcnc-ethercat/tree/master/wip-meca500
Last edit: 4 years 3 months ago by ftree.
4 years 3 months ago #248021 by andypugh
Replied by andypugh on topic EtherCAT driver for a 6 axis robot
To do a timed sequence in a HAL component, you use a state machine.
{normal .comp headers, as you have} pin out signed state; pin out float timer; ... FUNCTION(_){ ... switch (state){ case 0: // waiting if (! enable) return; output_1 = 1; timer = 1000; state = 1; break; case 1: timer -= fperiod; if (timer > 0) return; output_2 = 1; timer = 1500; state = 2; break; case 2: timer -= fperiod; if (timer > 0) return; output_3 = 1; timer = 500; state = 3; . break; case 3: ...
4 years 3 months ago - 4 years 3 months ago #248028 by ftree
Thanks Andy. This is very much out of comfort zone. If anyone can help on a contract basis for the underlying code work please do let me know.
I have managed to assemble the obj models within vismach. I'm now figuring out the correct XYZ orientation to export obj files out as as well as the correct translations.
github.com/djsftree/linuxcnc-ethercat/bl...eca500/meca500gui.py
Time to create page: 0.222 seconds
