  • Fastfred
  • Fastfred
06 Dec 2025 22:32
Replied by Fastfred on topic Clearpath HLFB amp.joint.delay
Category: HAL
Do I start from scratch? do you mind giving a example how to configure this . Took me awhile just to try to get this far.
  • rodw
  • rodw's Avatar
06 Dec 2025 21:45
Replied by rodw on topic GCode Review
GCode Review
Category: CAD CAM
Tommy,
Thanks for the reminder about the on-machine simulation, that works fine.
I was hoping I had missed something in Camotics or NCViewer, or there was another product available that I could run at the design stage away from the machine.
Well, this shows I need to install LinuxCNC Simulator on my desktop.
John.
If your desktop is a Windows machine, you can use Virtualbox to host linuxcnc on.
  • electrosteam
  • electrosteam
06 Dec 2025 21:29
Replied by electrosteam on topic GCode Review
GCode Review
Category: CAD CAM
Tommy,
John.
  • rodw
  • rodw's Avatar
06 Dec 2025 20:15 - 06 Dec 2025 20:15
Real Time PREEMPT_RT Kernel Tuning including Networking
Category: Installing LinuxCNC
You might also want to disable IPv6 on the card, otherwise there are
some discovery packets sent. After the card is up, I use the following
command to turn of IPv6:
sysctl -w net.ipv6.conf.eth1.disable_ipv6=1
Thanks. It seems the simplest method is to add this to the GRUB command lineipv6.disable=1
  • JumpPadGames
  • JumpPadGames
06 Dec 2025 19:15
Can anyone please help me with testing my CAM software?
Category: Plasmac
I just need someone to test my CAM web app for bugs, feedback, and feature requests. Willing to add post processors to the software if its not there. The app is at plasmadesk.com no sign up works when u visit.
  • andrax
  • andrax's Avatar
06 Dec 2025 18:02
Replied by andrax on topic StepperOnline A6 Servo
Category: EtherCAT
Hello everyone,
After successfully getting the EtherCAT configuration for the A6 750W up and running, I ordered the remaining servos for my milling machine.
A word of warning in advance: I had a lot of trouble with German customs. If the value of the goods exceeds €150, you have to react quickly and submit all the necessary documents to DHL Express, otherwise the delivery will be sent straight back to China.
The servos ordered this time are not the A6 750W but the A6 400W (A6-EC400H2A1-M17-STO). I thought I would just have to duplicate the entries in Ethercat.xml and only adjust the slave idx=.
That doesn't work. The A6 400W use completely different addresses.
Here is an excerpt from the Ethercat configuration:
A6 750W
=== Master 0, Slave 0 ===
SM0: PhysAddr 0x1000, DefaultSize  256, ControlRegister 0x26, Enable 1
SM1: PhysAddr 0x1400, DefaultSize  256, ControlRegister 0x22, Enable 1
SM2: PhysAddr 0x1800, DefaultSize   12, ControlRegister 0x64, Enable 1
  RxPDO 0x1600 ""
    PDO entry 0x6040:00, 16 bit, ""
    PDO entry 0x6060:00,  8 bit, ""
    PDO entry 0x607a:00, 32 bit, ""
    PDO entry 0x60ff:00, 32 bit, ""
    PDO entry 0x607c:00, 32 bit, ""
    PDO entry 0x6098:00,  8 bit, ""
    PDO entry 0x6099:01, 32 bit, ""
    PDO entry 0x6099:02, 32 bit, ""
    PDO entry 0x609a:00, 32 bit, ""
SM3: PhysAddr 0x1c00, DefaultSize   28, ControlRegister 0x20, Enable 1
  TxPDO 0x1a00 ""
    PDO entry 0x6041:00, 16 bit, ""
    PDO entry 0x6061:00,  8 bit, ""
    PDO entry 0x6064:00, 32 bit, ""
    PDO entry 0x606c:00, 32 bit, ""
    PDO entry 0x6077:00, 16 bit, ""
A6 400W
=== Master 0, Slave 1 ===
  RxPDO 0x1701 ""
    PDO entry 0x60b8:00, 16 bit, ""
    PDO entry 0x60fe:01, 32 bit, ""
  TxPDO 0x1b01 ""
    PDO entry 0x603f:00, 16 bit, ""
    PDO entry 0x60f4:00, 32 bit, ""
    PDO entry 0x60b9:00, 16 bit, ""
    PDO entry 0x60ba:00, 32 bit, ""
    PDO entry 0x60bc:00, 32 bit, ""
    PDO entry 0x60fd:00, 32 bit, ""
This means I have to rewrite the xml for the A6 400W.
As soon as I'm done and the configuration is running, I'll upload it here.
Andre
  • endian
  • endian's Avatar
06 Dec 2025 15:20
Replied by endian on topic Reduce read-all timing 7i76e + 7i77
sudo apt install linux-cpupower
sudo cpupower frequency-set --governor performance
I have had loong time before network tunning done this ... it is basic stuff for latency reduction at any hardware
I will do the kill of EEE and I will share the resaults in comming weeks .. thanks for hint !
  • COFHAL
  • COFHAL
06 Dec 2025 15:13
Replied by COFHAL on topic wiring MPGs to 7i96s
Category: Driver Boards
File Name: MPG.hal
File Size:2 KB
  • mark-v-d
  • mark-v-d
06 Dec 2025 14:07
  • rodw
  • rodw's Avatar
06 Dec 2025 13:46
Looking for a freelancer to assist in drawing schematics for cnc plasma table
Category: User Exchange
It is indeed a long list.
Where in the world is this table going to be built?
I noticed RS485 specified for servos which is not suitable.
I share others concerns about gantry weight but don't know table size.
I have built complete plasma controllers that were shipped to the customer previously and selected motors and gearboxes etc.
ref:
In the absence of PM;s here, you can contact me in the first instance via the email on my YouTube channel
www.youtube.com/@MrRodW
  • Hakan
  • Hakan
06 Dec 2025 13:45 - 06 Dec 2025 13:46
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
"Run" top menu option, Start debugging. There will come a green play button, step button and some more at some point.
Click left of the line number to add breakpoint. Right-click variable and add to watchlist. And much more
  • vibram
  • vibram
06 Dec 2025 12:49 - 06 Dec 2025 13:38
Replied by vibram on topic AX58100
AX58100
Category: EtherCAT
Great thank you for your support.
How do you debug in your platformio project?
I will create my usbject once I made some progress
Meanwhile I remove pin SYNC0 and SYNC1 but its not working anymore with the original project, i will need to adapt with yours :)
  • rodw
  • rodw's Avatar
06 Dec 2025 12:39
My latest video is 28 minutes of pure gold for those needing to minimize network and system latency on Debian Bookworm and Trixie
The info assembled here is scattered and its never been available in one place. Also, many articles on the internet refer to obsolete applications no longer in Debian Bookworm or Trixie (for good reasons).
This video covers how to:
1. Configure the GRUB kernel settings
2.  CPU Governor set to performance
3. NIC coalescence disabled for Intel network cards
4. Network driver correctly installed and configured
5. CPU core isolated for LinuxCNC Real time process.
6. IRQ for Network card identified and set to Isolated core
7. Outlines why irqbalance should NOT be installed
Also, whilst kernel documentation states energy efficient ethernet is disabled by default but this is not always the case. Whilst some NIC's allow it to be disabled with GRUB parameters, there is no standard so different network interfaces need different treatment with hard to find parameters. We show how to create a service that disabled all NIC's. This requires a configuration file attached (to be used in conjunction with the video) that I have attached as a convenience here.
This has been one of the hardest LinucCNC tutorials I have ever put together. Please provide feedback here and as comments on the Youtube video. Enjoy!
  • Hakan
  • Hakan
06 Dec 2025 12:28
AX58100
Category: EtherCAT
Sure, let's do that.
Best to start your own thread I guess.
I propose you do it in two steps
1. get encoder working
2. ethercat.
  • vibram
  • vibram
06 Dec 2025 12:17
AX58100
Category: EtherCAT
Hello @Hakan
I received the board and it worked smoothly with the firmware inside.
However I have a lot of issue to edit, mainly I think due to chinese chars that are not converted correctly.
The TIM2 CH1 and CH2 are quite easily accessible. Do you want to help/assist me in order to build the new firmware ?
I think i can take you firmware and edit it, I feel almost capable, however regarding the eeprom etc I'm totally lost.
Maybe we can try step by step?
Displaying 10216 - 10230 out of 11520 results.
Time to create page: 0.573 seconds
